Ana içeriğe geç
ASUS Q405U Battery Replacement
Neye ihtiyacın var
  1. ASUS Q405U Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS Q405U Battery Replacement: adım 2, 1 resimden 1.
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS Q405U Battery Replacement: adım 3, 3 resimden 1. ASUS Q405U Battery Replacement: adım 3, 3 resimden 2. ASUS Q405U Battery Replacement: adım 3, 3 resimden 3.
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
    FixBot'a Sor
    Yorum Ekle
  4. ASUS Q405U Battery Replacement: adım 4, 2 resimden 1. ASUS Q405U Battery Replacement: adım 4, 2 resimden 2.
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS Q405U Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS Q405U Battery Replacement: adım 6, 1 resimden 1.
    • Once all screws are removed, lift the battery out from the base of the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 farklı kişi bu kılavuzu tamamladı.
Jeremiah Baselice
569 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G8
4 Üyeler
1Rehber Yorum
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 2,753
