Ana içeriğe geç
ASUS Q405U Battery Replacement
  1. ASUS Q405U Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Battery Replacement: adım 2, 1 resimden 1.
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Battery Replacement: adım 3, 3 resimden 1. ASUS Q405U Battery Replacement: adım 3, 3 resimden 2. ASUS Q405U Battery Replacement: adım 3, 3 resimden 3.
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Battery Replacement: adım 5, 1 resimden 1.
    • Once all screws are removed, lift the battery out from the base of the computer.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Bir başkası bu kılavuzu tamamladı.
Jeremiah Baselice
545 İtibar
5 adet Kılavuz yazıldı
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G8
4 Üyeler
One Comment
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 62
Her zaman: 773
