Ana içeriğe geç
ASUS ROG Raikiri Pro Battery Replacement
Neye ihtiyacın var
  1. ASUS ROG Raikiri Pro Battery Replacement, Battery: adım 1, 3 resimden 1. ASUS ROG Raikiri Pro Battery Replacement, Battery: adım 1, 3 resimden 2. ASUS ROG Raikiri Pro Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS ROG Raikiri Pro Battery Replacement: adım 2, 3 resimden 1. ASUS ROG Raikiri Pro Battery Replacement: adım 2, 3 resimden 2. ASUS ROG Raikiri Pro Battery Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS ROG Raikiri Pro Battery Replacement: adım 3, 2 resimden 1. ASUS ROG Raikiri Pro Battery Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS ROG Raikiri Pro Battery Replacement: adım 4, 2 resimden 1. ASUS ROG Raikiri Pro Battery Replacement: adım 4, 2 resimden 2.
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS ROG Raikiri Pro Battery Replacement: adım 5, 2 resimden 1. ASUS ROG Raikiri Pro Battery Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS ROG Raikiri Pro Battery Replacement: adım 6, 2 resimden 1. ASUS ROG Raikiri Pro Battery Replacement: adım 6, 2 resimden 2.
    • Use a spudger to carefully remove the board and left rumble motor.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS ROG Raikiri Pro Battery Replacement: adım 7, 2 resimden 1. ASUS ROG Raikiri Pro Battery Replacement: adım 7, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  8. ASUS ROG Raikiri Pro Battery Replacement: adım 8, 1 resimden 1.
    • Gently remove the battery from its enclosure.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 67
Her zaman: 847
