Ana içeriğe geç
ASUS ROG Raikiri Pro Case Replacement
Neye ihtiyacın var
  1. ASUS ROG Raikiri Pro Case Replacement, Battery: adım 1, 3 resimden 1. ASUS ROG Raikiri Pro Case Replacement, Battery: adım 1, 3 resimden 2. ASUS ROG Raikiri Pro Case Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS ROG Raikiri Pro Case Replacement: adım 2, 3 resimden 1. ASUS ROG Raikiri Pro Case Replacement: adım 2, 3 resimden 2. ASUS ROG Raikiri Pro Case Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS ROG Raikiri Pro Case Replacement: adım 3, 2 resimden 1. ASUS ROG Raikiri Pro Case Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS ROG Raikiri Pro Case Replacement: adım 4, 2 resimden 1. ASUS ROG Raikiri Pro Case Replacement: adım 4, 2 resimden 2.
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS ROG Raikiri Pro Case Replacement: adım 5, 2 resimden 1. ASUS ROG Raikiri Pro Case Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS ROG Raikiri Pro Case Replacement: adım 6, 2 resimden 1. ASUS ROG Raikiri Pro Case Replacement: adım 6, 2 resimden 2.
    • Use a spudger to carefully remove the board and left rumble motor.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS ROG Raikiri Pro Case Replacement: adım 7, 2 resimden 1. ASUS ROG Raikiri Pro Case Replacement: adım 7, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  8. ASUS ROG Raikiri Pro Case Replacement: adım 8, 1 resimden 1.
    • Gently remove the battery from its enclosure.
    FixBot'a Sor
    Yorum Ekle
  9. ASUS ROG Raikiri Pro Case Replacement, Motherboard: adım 9, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the right board.
    FixBot'a Sor
    Yorum Ekle
  10. ASUS ROG Raikiri Pro Case Replacement: adım 10, 1 resimden 1.
    • Use a spudger to carefully remove the right board.
    FixBot'a Sor
    Yorum Ekle
  11. ASUS ROG Raikiri Pro Case Replacement: adım 11, 1 resimden 1.
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    FixBot'a Sor
    Yorum Ekle
  12. ASUS ROG Raikiri Pro Case Replacement: adım 12, 1 resimden 1.
    • Using a Phillips #1 screwdriver to remove the six 8 mm screws holding the motherboard to the case.
    FixBot'a Sor
    Yorum Ekle
  13. ASUS ROG Raikiri Pro Case Replacement: adım 13, 1 resimden 1.
    • Use tweezers to disconnect the ribbon cable from the top of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. ASUS ROG Raikiri Pro Case Replacement: adım 14, 1 resimden 1.
    • Remove the motherboard from the case.
    • Be careful when removing the motherboard so you don't damage the USB-C connector.
    FixBot'a Sor
    Yorum Ekle
  15. ASUS ROG Raikiri Pro Case Replacement, Case: adım 15, 1 resimden 1.
    • Flip the top case so the front is facing down and pop out the action buttons if they don't fall out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 112
Her zaman: 777
