Ana içeriğe geç
ASUS ROG Spatha X Battery Replacement
Neye ihtiyacın var
    1. ASUS ROG Spatha X Battery Replacement, Mouse Cover: adım 1, 3 resimden 1. ASUS ROG Spatha X Battery Replacement, Mouse Cover: adım 1, 3 resimden 2. ASUS ROG Spatha X Battery Replacement, Mouse Cover: adım 1, 3 resimden 3.
      • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
      • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
      • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ROG Spatha X Battery Replacement: adım 2, 2 resimden 1. ASUS ROG Spatha X Battery Replacement: adım 2, 2 resimden 2.
      • Lift the upper mouse cover up and off.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS ROG Spatha X Battery Replacement, Battery: adım 3, 3 resimden 1. ASUS ROG Spatha X Battery Replacement, Battery: adım 3, 3 resimden 2. ASUS ROG Spatha X Battery Replacement, Battery: adım 3, 3 resimden 3.
      • Grip the white battery connector and pull it up and out of its motherboard socket.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS ROG Spatha X Battery Replacement: adım 4, 2 resimden 1. ASUS ROG Spatha X Battery Replacement: adım 4, 2 resimden 2.
      • Disconnect the side button assembly ribbon cable from the motherboard.
      • Use an opening tool to gently pry the battery up and out of the chassis.
      • Take care not to bend, twist, or puncture the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
cgrabowski1
678 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Botvin Spring 2025 UMass Dartmouth, Team 3-4, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G4
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 79
Her zaman: 670
