Ana içeriğe geç
ASUS ROG Strix GL503VD-DB71 Battery Replacement
Neye ihtiyacın var
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: adım 1, 2 resimden 1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 2, 3 resimden 1. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 2, 3 resimden 2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 3, 3 resimden 1. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 3, 3 resimden 2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 3, 3 resimden 3.
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 4, 3 resimden 1. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 4, 3 resimden 2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: adım 4, 3 resimden 3.
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 85
Her zaman: 5,090
