Ana içeriğe geç
ASUS TUF Gaming FX505GT Battery Replacement
Neye ihtiyacın var
  1. ASUS TUF Gaming FX505GT Battery Replacement, Battery: adım 1, 2 resimden 1. ASUS TUF Gaming FX505GT Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Shut down the device completely by pressing the power button for about five to ten seconds, and unplug the charger.
  2. ASUS TUF Gaming FX505GT Battery Replacement: adım 2, 3 resimden 1. ASUS TUF Gaming FX505GT Battery Replacement: adım 2, 3 resimden 2. ASUS TUF Gaming FX505GT Battery Replacement: adım 2, 3 resimden 3.
    • Gently flip the laptop so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 14 mm screws found on the bottom and the left and right sides of the laptop.
    • Remove the five 7 mm PH1 screws found on the top and middle of your device.
  3. ASUS TUF Gaming FX505GT Battery Replacement: adım 3, 2 resimden 1. ASUS TUF Gaming FX505GT Battery Replacement: adım 3, 2 resimden 2.
    • Use a spudger to pry the back panel from the laptop.
    • Work around the perimeter between the back case and the base, releasing any clips as you go.
    • Remove the back cover.
  4. ASUS TUF Gaming FX505GT Battery Replacement: adım 4, 2 resimden 1. ASUS TUF Gaming FX505GT Battery Replacement: adım 4, 2 resimden 2.
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
  5. ASUS TUF Gaming FX505GT Battery Replacement: adım 5, 2 resimden 1. ASUS TUF Gaming FX505GT Battery Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 7 mm screw securing the battery.
    • Carefully lift the battery out of the laptop.
Sonuç
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide. Take your e-waste to an R2 or e-Stewards certified recycler.
Matthew Harewood
121 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 87
