Ana içeriğe geç
Abask J05 Battery Replacement
Neye ihtiyacın var
  1. Abask J05 Battery Replacement, Front Case: adım 1, 2 resimden 1. Abask J05 Battery Replacement, Front Case: adım 1, 2 resimden 2.
    • Gently press on the SD card with a fingernail until it clicks.
    • Release, then remove the card.
    FixBot'a Sor
    Yorum Ekle
  2. Abask J05 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the 5 mm screw from the side of the device next to the suction cup dock with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Abask J05 Battery Replacement: adım 3, 2 resimden 1. Abask J05 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the two 8 mm screws from opposite sides of the screen with a Phillips #00 precision screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Abask J05 Battery Replacement: adım 4, 2 resimden 1. Abask J05 Battery Replacement: adım 4, 2 resimden 2.
    • Gently lift the screen.
    • Push up on the interior camera portion of the device. It should pop out of the socket. Being careful to keep the wires attached, set it to the side.
    FixBot'a Sor
    Yorum Ekle
  5. Abask J05 Battery Replacement: adım 5, 2 resimden 1. Abask J05 Battery Replacement: adım 5, 2 resimden 2.
    • Reach into the device with a spudger to release the top two snap joints keeping the end cap attached one at a time until the front face lifts off.
    • Be careful not to touch the screen.
    • Repeat the process with the two remaining snap joints.
    FixBot'a Sor
    Yorum Ekle
  6. Abask J05 Battery Replacement, Screen: adım 6, 2 resimden 1. Abask J05 Battery Replacement, Screen: adım 6, 2 resimden 2.
    • Remove the two 7 mm screws on the side of the motherboard with a Phillips #00 screwdriver.
    • Slowly pull up on each corner of the motherboard, stopping when the corner pops loose of the anchor.
    • Repeat the process with each corner before slowly pulling up on the board to detach the glue on the underside.
    FixBot'a Sor
    Yorum Ekle
  7. Abask J05 Battery Replacement: adım 7, 3 resimden 1. Abask J05 Battery Replacement: adım 7, 3 resimden 2. Abask J05 Battery Replacement: adım 7, 3 resimden 3.
    • Carefully flip over the motherboard, being mindful of the wires.
    • Remove the two 5mm screws on the underside of the motherboard with a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Abask J05 Battery Replacement: adım 8, 2 resimden 1. Abask J05 Battery Replacement: adım 8, 2 resimden 2.
    • Follow the golden ribbon from the screen to the screen dock. Push the two small black stubs on either side of the dock away from the dock until it pops loose.
    • Remove the ribbon and the small plastic piece from the dock.
    FixBot'a Sor
    Yorum Ekle
  9. Abask J05 Battery Replacement: adım 9, 2 resimden 1. Abask J05 Battery Replacement: adım 9, 2 resimden 2.
    • Gently pull up on each corner of the white screen piece until the adhesive comes loose.
    • Remove the screen fully from its holder.
    FixBot'a Sor
    Yorum Ekle
  10. Abask J05 Battery Replacement, Motherboard: adım 10, 3 resimden 1. Abask J05 Battery Replacement, Motherboard: adım 10, 3 resimden 2. Abask J05 Battery Replacement, Motherboard: adım 10, 3 resimden 3.
    • Desolder the red wire attached to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Abask J05 Battery Replacement: adım 11, 2 resimden 1. Abask J05 Battery Replacement: adım 11, 2 resimden 2.
    • Detach the ribbon cable connecting the motherboard to the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  12. Abask J05 Battery Replacement: adım 12, 2 resimden 1. Abask J05 Battery Replacement: adım 12, 2 resimden 2.
    • Desolder all four wires connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Abask J05 Battery Replacement: adım 13, 1 resimden 1.
    • Remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  14. Abask J05 Battery Replacement, Battery: adım 14, 2 resimden 1. Abask J05 Battery Replacement, Battery: adım 14, 2 resimden 2.
    • Heat the iOpener as instructed, then place it over the battery.
    • Check periodically to see whether the glue has melted.
    • This should take about 5-15 minutes.
    FixBot'a Sor
    Yorum Ekle
  15. Abask J05 Battery Replacement: adım 15, 3 resimden 1. Abask J05 Battery Replacement: adım 15, 3 resimden 2. Abask J05 Battery Replacement: adım 15, 3 resimden 3.
    • Peel off the tape on the battery.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. (Note: When doing the steps in reverse order, do not do Step 5. Instead, place the front face of the device back on the main body before lining up the endcap, ensuring proper orientation with the SD card slot, and push in until you hear all four snap joints snap into place.)
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 518
