Ana içeriğe geç
Acer Aspire 3 A315-24P-R7VH Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire 3 A315-24P-R7VH Battery Replacement, Lower Case: adım 1, 1 resimden 1.
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 2, 2 resimden 1. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 2, 2 resimden 2.
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 3, 1 resimden 1.
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Grip the white battery connector and pull it directly out of its socket.
    • Do not pull on the wires.
  6. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 6, 2 resimden 1. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 6, 2 resimden 2.
    • Unscrew the four 4.5 mm Phillips head screws that secure the battery.
  7. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 7, 2 resimden 1. Acer Aspire 3 A315-24P-R7VH Battery Replacement: adım 7, 2 resimden 2.
    • Lift the battery up and out of the chassis.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Patrick Smith
197 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Fall 2023 Gateway, Team 1-1, Pee Fall 2023 üyesi
GCC-PEE-F23S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 69
Her zaman: 296
