Ana içeriğe geç
Acer E5-571-54FL Battery Replacement
Neye ihtiyacın var
  1. Acer E5-571-54FL Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Battery Replacement: adım 2, 2 resimden 1. Acer E5-571-54FL Battery Replacement: adım 2, 2 resimden 2.
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Battery Replacement: adım 3, 2 resimden 1. Acer E5-571-54FL Battery Replacement: adım 3, 2 resimden 2.
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Aaron Weissman
1.004 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 UMass Dartmouth, Team S3-G8, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 59
Her zaman: 2,632
