Ana içeriğe geç
Acer Predator Helios 300 (2020) Battery Replacement
Neye ihtiyacın var
  1. Acer Predator Helios 300 (2020) Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Predator Helios 300 (2020) Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the laptop by holding the power button for 7 seconds.
  2. Acer Predator Helios 300 (2020) Battery Replacement: adım 2, 2 resimden 1. Acer Predator Helios 300 (2020) Battery Replacement: adım 2, 2 resimden 2.
    • Remove the eleven black 7.0 mm screws using a Phillips #00 screwdriver.
  3. Acer Predator Helios 300 (2020) Battery Replacement: adım 3, 2 resimden 1. Acer Predator Helios 300 (2020) Battery Replacement: adım 3, 2 resimden 2.
    • Put your hands on the white part of the chassis and pull up until you hear a snap.
    • Lift up the back panel and remove it from the device.
  4. Acer Predator Helios 300 (2020) Battery Replacement: adım 4, 3 resimden 1. Acer Predator Helios 300 (2020) Battery Replacement: adım 4, 3 resimden 2. Acer Predator Helios 300 (2020) Battery Replacement: adım 4, 3 resimden 3.
    • Remove the two 4.0 mm golden screws using the Phillips #00 screwdriver.
  5. Acer Predator Helios 300 (2020) Battery Replacement: adım 5, 3 resimden 1. Acer Predator Helios 300 (2020) Battery Replacement: adım 5, 3 resimden 2. Acer Predator Helios 300 (2020) Battery Replacement: adım 5, 3 resimden 3.
    • Disconnect the battery connector.
  6. Acer Predator Helios 300 (2020) Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the laptop.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 farklı kişi bu kılavuzu tamamladı.
Steven Yuen
349 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
Jeff Noble - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 70
Son 30 gün: 334
Her zaman: 11,720
