Ana içeriğe geç
Acer Spin 5 N17W2 Battery Replacement
Neye ihtiyacın var
  1. Acer Spin 5 N17W2 Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Spin 5 N17W2 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Battery Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Battery Replacement: adım 3, 1 resimden 1.
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Battery Replacement: adım 4, 1 resimden 1.
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Battery Replacement: adım 5, 1 resimden 1.
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Do you guys sell this exact battery replacement?
Sara B - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 26
Son 30 gün: 87
Her zaman: 10,050
