Ana içeriğe geç
Acer Swift 3 2022 Fan Replacement
Anna Miller
Anna Miller ve 2 diğer katkıda bulunanlar
En son December 22, 2022 tarihinde güncellendi
10 - 15 dakika
Kolay
Acer Swift 3 2022 Model Number: N20C12
If your Acer Swift 3 2022 is exhibiting a constant buzzing and humming noise and is overheating, use this guide to remedy those problems. This relatively easy procedure will have your computer as silent as when you first got it and no longer hot to the touch.
Before following this guide, try to remove dust and debris from the fan. This can be accomplished by using an ESD-safe brush or small dust blower and directing it at the fan located in the inner portion of the laptop. This should be completed before following through with the replacement. To view more information view our troubleshooting page.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Acer Swift 3 2022 Fan Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Fan Replacement: adım 2, 2 resimden 1. Acer Swift 3 2022 Fan Replacement: adım 2, 2 resimden 2.
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Fan Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: adım 4, 3 resimden 1. Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: adım 4, 3 resimden 2. Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: adım 4, 3 resimden 3.
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Fan Replacement: adım 5, 2 resimden 1. Acer Swift 3 2022 Fan Replacement: adım 5, 2 resimden 2.
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Fan Replacement, Fan: adım 6, 2 resimden 1. Acer Swift 3 2022 Fan Replacement, Fan: adım 6, 2 resimden 2.
    • Remove the two 4.5 mm screws from the fan using a Phillips #00 screwdriver.
  7. Acer Swift 3 2022 Fan Replacement: adım 7, 2 resimden 1. Acer Swift 3 2022 Fan Replacement: adım 7, 2 resimden 2.
    • Lift the metal clip using the iFixit opening tool to release the wire.
  8. Acer Swift 3 2022 Fan Replacement: adım 8, 3 resimden 1. Acer Swift 3 2022 Fan Replacement: adım 8, 3 resimden 2. Acer Swift 3 2022 Fan Replacement: adım 8, 3 resimden 3.
    • Unplug the wires by pulling gently on the white plastic.
  9. Acer Swift 3 2022 Fan Replacement: adım 9, 1 resimden 1.
    • Remove fan.
Sonuç
Anna Miller
888 İtibar
6 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G2
2 Üyeler
1Rehber Yorum
Correction. The fan should face the other way around - with the vent into the radiators of the heatsink. If the fan is placed incorrectly, overheating will occur.
Yehor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 53
Her zaman: 1,041
