Ana içeriğe geç
Alcatel 1B 2020 Screen Replacement
Neye ihtiyacın var
  1. Alcatel 1B 2020 Screen Replacement, Battery: adım 1, 3 resimden 1. Alcatel 1B 2020 Screen Replacement, Battery: adım 1, 3 resimden 2. Alcatel 1B 2020 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • For your safety, unplug all peripherals, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Insert the opening tool into the seam between the back plastic case and the front screen.
    • Slide it around the edge of the phone to release the clips holding them together.
    • Remove the bottom case by hand.
    FixBot'a Sor
    Yorum Ekle
  2. Alcatel 1B 2020 Screen Replacement: adım 2, 3 resimden 1. Alcatel 1B 2020 Screen Replacement: adım 2, 3 resimden 2. Alcatel 1B 2020 Screen Replacement: adım 2, 3 resimden 3.
    • Place the pry tool between the bottom of the battery and the bracket.
    • Lift the battery using the pry tool to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Alcatel 1B 2020 Screen Replacement, Rear Camera: adım 3, 3 resimden 1. Alcatel 1B 2020 Screen Replacement, Rear Camera: adım 3, 3 resimden 2. Alcatel 1B 2020 Screen Replacement, Rear Camera: adım 3, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove sixteen 3.0 mm screws that secure the black plastic bracket.
    FixBot'a Sor
    Yorum Ekle
  4. Alcatel 1B 2020 Screen Replacement: adım 4, 3 resimden 1. Alcatel 1B 2020 Screen Replacement: adım 4, 3 resimden 2. Alcatel 1B 2020 Screen Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to pry the midframe from the bottom case.
    • Slide the end of the opening tool around the perimeter of the device to release the clips holding the midframe and bottom case together.
    • Be careful, the motherboard is located right beneath the midframe.
    • Remove the midframe from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Alcatel 1B 2020 Screen Replacement: adım 5, 3 resimden 1. Alcatel 1B 2020 Screen Replacement: adım 5, 3 resimden 2. Alcatel 1B 2020 Screen Replacement: adım 5, 3 resimden 3.
    • Place a spudger or an opening tool under the camera press connector edge and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • Use the tweezers to pull the rear camera out.
    FixBot'a Sor
    Yorum Ekle
  6. Alcatel 1B 2020 Screen Replacement, Motherboard: adım 6, 2 resimden 1. Alcatel 1B 2020 Screen Replacement, Motherboard: adım 6, 2 resimden 2.
    • Insert a spudger or opening tool under the edge of the front camera cable connector and pry straight up to disconnect it.
    • Disconnect the other two press connectors near the red part of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Alcatel 1B 2020 Screen Replacement: adım 7, 3 resimden 1. Alcatel 1B 2020 Screen Replacement: adım 7, 3 resimden 2. Alcatel 1B 2020 Screen Replacement: adım 7, 3 resimden 3.
    • Use tweezers to remove the motherboard from the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Alcatel 1B 2020 Screen Replacement, Front Camera: adım 8, 3 resimden 1. Alcatel 1B 2020 Screen Replacement, Front Camera: adım 8, 3 resimden 2. Alcatel 1B 2020 Screen Replacement, Front Camera: adım 8, 3 resimden 3.
    • Place the motherboard to the side.
    • The front camera ribbon connector was already removed in the previous step.
    • Use tweezers to pull the front-facing camera from the smartphone.
    FixBot'a Sor
    Yorum Ekle
  9. Alcatel 1B 2020 Screen Replacement, Screen: adım 9, 3 resimden 1. Alcatel 1B 2020 Screen Replacement, Screen: adım 9, 3 resimden 2. Alcatel 1B 2020 Screen Replacement, Screen: adım 9, 3 resimden 3.
    • Flip your Alcatel 1B 2020 face up so the screen is facing you.
    • Slide the edge of the Jimmy between the case and the screen to pry it from the phone.
    • Insert opening picks under the screen as you work around the edge with the Jimmy to keep the adhesive from reattaching.
    FixBot'a Sor
    Yorum Ekle
  10. Alcatel 1B 2020 Screen Replacement: adım 10, 3 resimden 1. Alcatel 1B 2020 Screen Replacement: adım 10, 3 resimden 2. Alcatel 1B 2020 Screen Replacement: adım 10, 3 resimden 3.
    • The screen will eventually lift with enough prying.
    • Flip the device over.
    • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
    • Carefully slide the ribbon cable out from the opening at the edge of the frame.
    FixBot'a Sor
    Yorum Ekle
  11. Alcatel 1B 2020 Screen Replacement: adım 11, 3 resimden 1. Alcatel 1B 2020 Screen Replacement: adım 11, 3 resimden 2. Alcatel 1B 2020 Screen Replacement: adım 11, 3 resimden 3.
    • Flip the device back over.
    • The LCD screen is very fragile. Be careful when prying and handling it.
    • The ribbon connector for the LCD screen was disconnected in the previous step, so the screen will pop up using the Jimmy.
    • Slide the Jimmy between the LCD and the digitizer to separate the two components.
    • Lift the LCD screen out with tweezers or your hands.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 77
