Ana içeriğe geç
Alcatel One Touch Evolve 2 Headphone Jack Replacement
Neye ihtiyacın var
  1. Alcatel One Touch Evolve 2 Headphone Jack Replacement, Back Frame: adım 1, 3 resimden 1. Alcatel One Touch Evolve 2 Headphone Jack Replacement, Back Frame: adım 1, 3 resimden 2. Alcatel One Touch Evolve 2 Headphone Jack Replacement, Back Frame: adım 1, 3 resimden 3.
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 4, 3 resimden 1. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 4, 3 resimden 2. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 5, 2 resimden 1. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Pull the rear frame off with your hands.
  6. Alcatel One Touch Evolve 2 Headphone Jack Replacement, Main Circuit Board: adım 6, 2 resimden 1. Alcatel One Touch Evolve 2 Headphone Jack Replacement, Main Circuit Board: adım 6, 2 resimden 2.
    • Use a plastic opening tool to pop the speaker press-fit connector free.
    • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
  7. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 7, 1 resimden 1.
    • Use a plastic opening tool to lift the front camera press-fit connector free.
  8. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 8, 1 resimden 1.
    • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
  9. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 9, 1 resimden 1.
    • Detach the main circuit board from the front cover.
  10. Alcatel One Touch Evolve 2 Headphone Jack Replacement, Headphone Jack: adım 10, 1 resimden 1.
    • Remove the black electric tape covering the headphone jack.
  11. Alcatel One Touch Evolve 2 Headphone Jack Replacement: adım 11, 1 resimden 1.
    • Flip motherboard upside-down and desolder the pins connecting the headphone jack to the motherboard.
    • Once the pins are desoldered, pull the headphone jack out.
    • If you need instructions on how to solder/desolder electronic connections, here is a link to the Soldering Technique Guide
Sonuç
Andrew Bai
634 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 449
