Ana içeriğe geç
Amazon Echo Show 10 3rd Gen Woofer Replacement
Neye ihtiyacın var
  1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: adım 1, 2 resimden 1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: adım 1, 2 resimden 2.
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Woofer Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
  3. Amazon Echo Show 10 3rd Gen Woofer Replacement: adım 3, 2 resimden 1. Amazon Echo Show 10 3rd Gen Woofer Replacement: adım 3, 2 resimden 2.
    • Use an opening tool to pry up along the edge of the speaker.
    • Gently lift the woofer out of the device.
    • The woofer is connected to a cable so don't yank it out or you will damage the connector.
  4. Amazon Echo Show 10 3rd Gen Woofer Replacement: adım 4, 1 resimden 1.
    • Tilt the woofer so the side with the cables is angled upwards.
    • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
    • For information on soldering, refer to the How to Solder and Desolder Connections guide.
  5. Amazon Echo Show 10 3rd Gen Woofer Replacement: adım 5, 1 resimden 1.
    • After desoldering the three cables, lift the woofer out of the shell of the device.
Sonuç
Macy Ormand
1.073 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 90
