Ana içeriğe geç
Amazon Fire TV Stick Remote Button Panel Replacement
Neye ihtiyacın var
  1. Amazon Fire TV Stick Remote Button Panel Replacement, Remote Button Panel: adım 1, 3 resimden 1. Amazon Fire TV Stick Remote Button Panel Replacement, Remote Button Panel: adım 1, 3 resimden 2. Amazon Fire TV Stick Remote Button Panel Replacement, Remote Button Panel: adım 1, 3 resimden 3.
    • To remove the buttons use the blue plastic opening tool to pry out the outer ring.
  2. Amazon Fire TV Stick Remote Button Panel Replacement: adım 2, 2 resimden 1. Amazon Fire TV Stick Remote Button Panel Replacement: adım 2, 2 resimden 2.
    • Remove the inner disk.
    BEWARE! I took the circular button off because, after dropping the remote, the circle would not press down on the right side, however, all of the other functions (up, down, left and the center select button were working fine). After popping the circular button out and putting it back in, now none of the controls will press down. I'm sure it probably just needs to be aligned better but how exactly?
    Judith B - Yanıt
  3. Amazon Fire TV Stick Remote Button Panel Replacement: adım 3, 2 resimden 1. Amazon Fire TV Stick Remote Button Panel Replacement: adım 3, 2 resimden 2.
    • Remove the 6mm triangle screw.
    Which screw driver you used for this, i looked at online and not sure size of screw.
    Akshay Rudraksha - Yanıt
    Mine does not have a screw under the button? So what now. It looks as if the remote has side clips that hold it togather?
    dbirdsell67 - Yanıt
  4. Amazon Fire TV Stick Remote Button Panel Replacement: adım 4, 2 resimden 1. Amazon Fire TV Stick Remote Button Panel Replacement: adım 4, 2 resimden 2.
    • Remove top plate using plastic opening tools.
  5. Amazon Fire TV Stick Remote Button Panel Replacement: adım 5, 2 resimden 1. Amazon Fire TV Stick Remote Button Panel Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sami Uzzama
630 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley SU 2016 IUPUI, Team 2-3, Harley SU 2016 üyesi
IUPUI-HARLEY-SU16S2G3
4 Üyeler
13 adet Kılavuz yazıldı
3 Yorum
Where do you get the replacement parts
Chris S - Yanıt
You could probably find them on eBay.
[deleted] -
All the Amazon remote repair guides here need updating as many generations have come out since this original basic edition shown here. There are at least six other versions outside of this one. https://www.amazon.com/gp/help/customer/...
deilert - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 139
Her zaman: 24,378
