Ana içeriğe geç
Amazon Luna Controller Joystick Cover Replacement
Cade Queen
Cade Queen ve 3 diğer katkıda bulunanlar
En son January 9, 2025 tarihinde güncellendi
20 - 30 dakika
Orta
If the joystick thumbstick on your Amazon Luna Controller is worn out, unresponsive, or dirty, it can hinder your gaming experience and impact control precision. Replacing or cleaning the thumbstick is a simple process that requires minimal technical expertise. This guide will walk you through the steps to safely remove and replace the thumbstick, ensuring your controller performs optimally.
Neye ihtiyacın var
Aletler
  1. Amazon Luna Controller Joystick Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Joystick Cover Replacement: adım 2, 3 resimden 1. Amazon Luna Controller Joystick Cover Replacement: adım 2, 3 resimden 2. Amazon Luna Controller Joystick Cover Replacement: adım 2, 3 resimden 3.
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Joystick Cover Replacement, Faceplate: adım 3, 1 resimden 1.
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Joystick Cover Replacement: adım 4, 1 resimden 1.
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Joystick Cover Replacement: adım 5, 2 resimden 1. Amazon Luna Controller Joystick Cover Replacement: adım 5, 2 resimden 2.
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Joystick Cover Replacement, Buttons: adım 6, 2 resimden 1. Amazon Luna Controller Joystick Cover Replacement, Buttons: adım 6, 2 resimden 2.
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Joystick Cover Replacement: adım 7, 2 resimden 1. Amazon Luna Controller Joystick Cover Replacement: adım 7, 2 resimden 2.
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Joystick Cover Replacement: adım 8, 3 resimden 1. Amazon Luna Controller Joystick Cover Replacement: adım 8, 3 resimden 2. Amazon Luna Controller Joystick Cover Replacement: adım 8, 3 resimden 3.
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
  9. Amazon Luna Controller Joystick Cover Replacement, Joystick Cover: adım 9, 2 resimden 1. Amazon Luna Controller Joystick Cover Replacement, Joystick Cover: adım 9, 2 resimden 2.
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cade Queen
537 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 72
