Ana içeriğe geç
Apple TV 4K Logic Board Replacement
Keenan Barber
Keenan Barber ve 6 diğer katkıda bulunanlar
En son October 23, 2023 tarihinde güncellendi
7 - 10 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
This guide will show you how to properly get into your Apple TV 4K device and get access to the logic board for replacement.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Apple TV 4K Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: adım 2, 2 resimden 1. Apple TV 4K Logic Board Replacement: adım 2, 2 resimden 2.
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: adım 3, 2 resimden 1. Apple TV 4K Logic Board Replacement: adım 3, 2 resimden 2.
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: adım 4, 1 resimden 1.
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: adım 5, 3 resimden 1. Apple TV 4K Logic Board Replacement: adım 5, 3 resimden 2. Apple TV 4K Logic Board Replacement: adım 5, 3 resimden 3.
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Keenan Barber
1.270 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G3
4 Üyeler
15 adet Kılavuz yazıldı
8 Yorum
Where does one get a new logic board??
MP94025 - Yanıt
Any idea on where I can purchase. new logic board?
tylerchumchal - Yanıt
Where do you buy the board…….
Andy Grichtmeier - Yanıt
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - Yanıt
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 30
Son 30 gün: 85
Her zaman: 9,186
