Ana içeriğe geç
Apple Watch Series 4 Force Touch Gasket Replacement
Neye ihtiyacın var
  1. Apple Watch Series 4 Force Touch Gasket Replacement, Display Opening: adım 1, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement, Display Opening: adım 1, 2 resimden 2.
    Hi. I changed the screen on an apple watch series 4, now the screen works, whcih is great, but when I charge it, the green snake comes on but never charges. It heats up the bottom, gets very warm. Could it be the battery itself? Maybe needs a new one? Is rthere anything else that woudl be causing the battery to not charge and or heat up on the bottom when chaging the screen?
    Derrick Brewer - Yanıt
  2. Apple Watch Series 4 Force Touch Gasket Replacement, Safety Requirements: adım 2, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement, Safety Requirements: adım 2, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement, Safety Requirements: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 4 Force Touch Gasket Replacement: adım 3, 1 resimden 1.
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  4. Apple Watch Series 4 Force Touch Gasket Replacement: adım 4, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 4, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 4, 3 resimden 3.
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the Force Touch sensor.
    This part is REALLY hard! Even after using the iOpener to warm the watch I had to use A LOT of force to get the blade in between the glass and the case. Be very careful when prying the display. I applied way too much force and my blade shot into the case under the display. I don’t think I damaged anything, but I did replace the force touch gasket to be sure.
    mdhicksmdhicks - Yanıt
    I have a stainless steel case, not sure if that makes a difference, and was unable to do this without breaking the screen. Be very careful. Followed instructions but could not get the screen to release no matter how hot I got the watch.
    Jason Michel - Yanıt
    I am moderately experienced at opening Apple devices having replaced batteries in several iPhones, iPods, and an iPad. I could not get the watch open with the x-acto knife blade as shown. I found other sites showed using a 0.1mm thick tool. I bought one and found it relatively easy to open the watch. It has the advantage of going in horizontal rather than vertical so it went between the glass and the force sense gasket. Force sense gasket wasn't disturbed at all. iFixit should add this type of tool to their offering.
    Dan Kelly - Yanıt
  5. Apple Watch Series 4 Force Touch Gasket Replacement: adım 5, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 5, 2 resimden 2.
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 4 Force Touch Gasket Replacement: adım 6, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 6, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 6, 3 resimden 3.
    • It's likely that the Force Touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
    This impossible for me. I just left the force touch gasket attached to the display side. I was able to bend the display back with the gasket still in place.
    See first the instructions for replacing the force touch gasket to familiarize yourself with parts that need separating. These instructions will seem unclear if you don't know what the force touch gasket looks like.
    Adam Richman - Yanıt
    Be very careful with this step. I accidentally tore the Force Touch gasket, and while trying to replace it, then tore the display flex cable, thereby ruining the watch.
    John - Yanıt
  7. Apple Watch Series 4 Force Touch Gasket Replacement: adım 7, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 7, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 7, 3 resimden 3.
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display at max. to an 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely. Since the adhesive needs to be replaced anyway, you can cut it if that makes removal easier for you.
    • Make sure to return to this point during the reassembly of your watch and then continue with the Resealing Procedure.
    Be careful to remove just the adhesive and not the force touch gasket itself!
    John - Yanıt
  8. Apple Watch Series 4 Force Touch Gasket Replacement, Battery: adım 8, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement, Battery: adım 8, 2 resimden 2.
    • Carefully fold the screen to the back until you get enough space to pry out the battery.
    • Avoid tensioning the display cables when folding the screen to the back.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44mm version of the Apple Watch Series 4. However if you own the 40mm version and don't have enough space you can customize your opening pick with scissors.
    If you are just replacing the screen then there is no need to remove battery.
    anonymous 1930 - Yanıt
    When removing the screen I tore the two outer cables attached to the lcd screen. What are their purpose? I read somewhere they are just some sort of shield. Will my watch function normally without them?
    thanks
    Mike Bahlman - Yanıt
  9. Apple Watch Series 4 Force Touch Gasket Replacement: adım 9, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 9, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 9, 3 resimden 3.
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
    • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  10. Apple Watch Series 4 Force Touch Gasket Replacement: adım 10, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 10, 2 resimden 2.
    • Carefully lift the battery and bring it in a 75° angle.
    • Use a pair of tweezers to peel the black sticker off the metal plate which covers the battery connector.
    Nothing is said about replacing the black sticker over the connector. I set it aside and found its adhesive was good enough to stay in place and put it back on during reassembly.
    Dan Kelly - Yanıt
  11. Apple Watch Series 4 Force Touch Gasket Replacement: adım 11, 1 resimden 1.
    • Remove the Y000 screw (1.2 mm length).
  12. Apple Watch Series 4 Force Touch Gasket Replacement: adım 12, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to remove the metal plate which covers the battery connector.
  13. Apple Watch Series 4 Force Touch Gasket Replacement: adım 13, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the battery flex cable.
  14. Apple Watch Series 4 Force Touch Gasket Replacement: adım 14, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 14, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • Be sure to remove the protective liner to expose the adhesive on your new battery before you set it in place.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
    When installing the new battery be aware that the sidewall of the watch directly above the contacts and cover screw hole is magnetized. This was shock to me and a little frustrating. Every time I attempted to place the cover with a tweezers it was pulled toward the sidewall. I pushed the plate in place with a spudger, then attached the screw to the tip of the screwdriver. I was then able to insert the screw with minimal disturbance to cover plate.
  15. Apple Watch Series 4 Force Touch Gasket Replacement, Screen Removal: adım 15, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement, Screen Removal: adım 15, 2 resimden 2.
    • The black foil which covers the display connectors is very fragile and likely to rip. To keep the tape intact while peeling it off, it's necessary to use high isopropyl alcohol or an iOpener.
    • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip and apply it to the black adhesive foil. Let it penetrate the adhesive for about two minutes.
    • Alternatively you can place an a heated iOpener on top of the screen to loosen the adhesive. Apply the iOpener at least for two minutes.
  16. Apple Watch Series 4 Force Touch Gasket Replacement: adım 16, 1 resimden 1.
    • Use a pair of tweezers to carefully peel off the tape covering the three display cable connectors.
  17. Apple Watch Series 4 Force Touch Gasket Replacement: adım 17, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 17, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 17, 3 resimden 3.
    • Use one arm of a pair of tweezers to carfully open the three ZIF connectors on the rear side of the screen.
  18. Apple Watch Series 4 Force Touch Gasket Replacement: adım 18, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 18, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 18, 3 resimden 3.
    • Use a pair of blunt nose tweezers to peel up the sides of the black foil which adheres the cable to the rear side of the screen.
    Be very careful not to damage the copper-colored ribbon cables at either end of the display flex cable. I found it impossible to remove the black foil without tearing these ribbons, and as my repair was ultimately unsuccessful, I have no doubt that this mistake was the cause of my failure. I wish this step had emphasized how difficult removing the foil could be. If you make the same mistake as I did, it will require advanced soldering to replace the display flex cable. That's a bridge too far for me with a 5+ year old watch, so it's off to the trash bin for it. Shame...
    John - Yanıt
  19. Apple Watch Series 4 Force Touch Gasket Replacement: adım 19, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 19, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 19, 3 resimden 3.
    • Lift the body of the watch up and carefully slide a spudger underneath the display flex cable to loosen remaining adhesive.
    See my comment to step 18.
    John - Yanıt
  20. Apple Watch Series 4 Force Touch Gasket Replacement: adım 20, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 20, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 20, 3 resimden 3.
    • Carefully pull the display flex cables out of their ZIF connectors.
    • Make sure to hold on to the display flex cable during this procedure and avoid pulling only on the body of the watch. Otherwise the display cable might rip.
    • Separate the watch assembly and the screen.
  21. Apple Watch Series 4 Force Touch Gasket Replacement, Force Touch Gasket: adım 21, 1 resimden 1.
  22. Apple Watch Series 4 Force Touch Gasket Replacement: adım 22, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers to remove the metal plate which covers the Force Touch gasket connector.
  23. Apple Watch Series 4 Force Touch Gasket Replacement: adım 23, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 23, 2 resimden 2.
    • Use the pointed end of a spudger to pry the Force Touch gasket connector out of its socket.
  24. Apple Watch Series 4 Force Touch Gasket Replacement: adım 24, 1 resimden 1.
    • Place a heated iOpener on the Force Touch connector to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  25. Apple Watch Series 4 Force Touch Gasket Replacement: adım 25, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 25, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 25, 3 resimden 3.
    • Use a pair of tweezers to remove the defective Force Touch gasket.
    • Avoid damaging the display flex cable when threading the Force Touch gasket connector through the gap between the adhesive foil and the display cable.
  26. Apple Watch Series 4 Force Touch Gasket Replacement: adım 26, 2 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 26, 2 resimden 2.
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the adhesive leftovers from the Force Touch gasket on the case and on the screen.
  27. Apple Watch Series 4 Force Touch Gasket Replacement: adım 27, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 27, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 27, 3 resimden 3.
    • Use a pair of tweezers to peel the new Force Touch gasket off the see-through backing film. Make sure you peel off the Force Touch gasket with both protective foils attached to it.
    • Peel off the protective foil from the bottom side of the Force Touch gasket. The bottom side is where the Force Touch connector faces.
  28. Apple Watch Series 4 Force Touch Gasket Replacement: adım 28, 3 resimden 1. Apple Watch Series 4 Force Touch Gasket Replacement: adım 28, 3 resimden 2. Apple Watch Series 4 Force Touch Gasket Replacement: adım 28, 3 resimden 3.
    • Hold the Force Touch gasket diagonally to thread it over the display cable. Make sure to position the Force Touch connector next to the home button.
    • Use the pointed end of a spudger to make final adjustments and press the Force Touch gasket into place.
Sonuç
To reassemble your Apple Watch Series 4 follow these instructions in reverse order to reattach the screen and the battery.
13 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
230.908 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.656 adet Kılavuz yazıldı
9Kılavuz Yorumları
Do I have to put also new adhesive or adhesive at the force touch is fine ?
cucflek - Yanıt
I have an Apple Watch SE 40mm that had a very cracked screen after falling on a tiled floor. Gift from my daughters for father's day, ouch!
Reputable service wanted 140.00 to replace the screen. I got cheap and got a kit on Amazon that had a screen with digitizer. Looked at videos on Apple Watch SE screen replacements on YouTube. Some great, & some bad. Watched over and over again the good ones.
Was able to get the screen off using heat gun. Released the latches and gently removed the three ribbon cables. Removed the adhesive strip that was kind of clear in appearance. Saw a light brown strip in the channel around the base of the watch. Thought it was part of the adhesive and pulled it out. Then I thought, sh*^t, was that the Force Touch Gasket! To make matters even worse the two ribbon cables on each side tore. I think they insulate the signals?? Looks like my beloved SE is toast thanks to me being a bone head! Should have sent it in for 140.00!
Andrew Douglas - Yanıt
Do I need to replace the Force Touch gasket even though it isn‘t used anymore sine WatchOS 7?
I mean while replacing a display glass do I need to keep the Force Touch intact?
Daniel Lux - Yanıt
Yes because you need to glue and fix the Display. It’s also for the water resistants. :)
Dennis Lehmann -
Is the adhesive supplied with a new Force Touch gasket to be used for subsequent screen removal and replacement? It appears the new Force Touch gasket has some adhesive after removal of the protective foil, is this correct?
Jim Kulyk - Yanıt
Production of the force touch gasket varies (sometimes with sometimes without adhesive). So if it should not come with adhesive, use the separate adhesive to close the watch. And yes, when already equipped with adhesive the extra can be used for subsequent openings.
Tobias Isakeit -
There is no mention of the adhesive, but the kit comes with 2 adhesive sheets.
How are those installed? One on the glass and one on the watch frame? Sandwiching the Force Touch sensor? Any considerations or tips?
Clayton Nicholson - Yanıt
What does the LCD adhere to? Does it adhere to the rim of the frame, or to the force touch sensor?
Will Drunkenstein - Yanıt
I would criticize this guide for one thing only, and that is the suggestion to remove the screen in the first place. The gasket and adhesive both can be fitted around the screen, and I found out the hard way that the ribbon connectors will NOT go back in their place easily, in fact, all I did was to push the connectors back in their place and try to push the plastic bar down, and the plastic broke before even light pressure. DO NOT remove the ZIF connectors, it is unnecessary and very risky.
Chris Michalski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 51
Son 30 gün: 363
Her zaman: 18,175
