Ana içeriğe geç
Astro A50 (2019) Battery Replacement
Neye ihtiyacın var
  1. Astro A50 (2019) Battery Replacement, Battery: adım 1, 2 resimden 1. Astro A50 (2019) Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the right side ear cushion by pulling toward you on the top tab.
  2. Astro A50 (2019) Battery Replacement: adım 2, 3 resimden 1. Astro A50 (2019) Battery Replacement: adım 2, 3 resimden 2. Astro A50 (2019) Battery Replacement: adım 2, 3 resimden 3.
    • Remove the speaker filter by using a prying tool and peeling it off.
    • Work your way around the filter until it comes off.
  3. Astro A50 (2019) Battery Replacement: adım 3, 3 resimden 1. Astro A50 (2019) Battery Replacement: adım 3, 3 resimden 2. Astro A50 (2019) Battery Replacement: adım 3, 3 resimden 3.
    • Remove all four 1.5 mm screws using the Phillips #00 screwdriver.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. Astro A50 (2019) Battery Replacement: adım 4, 3 resimden 1. Astro A50 (2019) Battery Replacement: adım 4, 3 resimden 2. Astro A50 (2019) Battery Replacement: adım 4, 3 resimden 3.
    • Remove all four 1.5 mm screws holding the motherboard using the Phillips #00 screwdriver.
    • Unplug the battery by pulling the plug.
  5. Astro A50 (2019) Battery Replacement: adım 5, 2 resimden 1. Astro A50 (2019) Battery Replacement: adım 5, 2 resimden 2.
    • Remove the old battery with a plastic opening tool.
    • Be careful to not puncture the battery or fold it.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 farklı kişi bu kılavuzu tamamladı.
Ekip
CSU Los Angeles, Team 11-6, Grodsky Fall 2021 CSU Los Angeles, Team 11-6, Grodsky Fall 2021 üyesi
CSULA-GRODSKY-F21S11G6
2 Üyeler
3 adet Kılavuz yazıldı
5 Yorum
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
Thomas Garcia - Yanıt
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
billy7183 - Yanıt
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft -
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
Wouter V - Yanıt
I performed this battery replacement. I sourced a new battery from another new A50 Gen 4 that was firmware bricked.
I’m having an issue charging the new battery with the base station. The headset does not seem to accept a charge from the base station however it will charge via a micro USB cable plugged into a usb wall brick.
I believe the issue is related to the battery not being calibrated to the old headset. Any ideas?
William Patterson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 141
Son 30 gün: 557
Her zaman: 9,168
