Giriş
Hello, today we will begin you repair of The Astro A50 Headset (2019). The most likely reason for you needing to repair this headset is either rage-quitting a game or simply your battery died & needs replacing. We did some searching on the web and couldn’t find any generous guides on how to repair. Just have to play harder so you don’t have worry about other kinds of repair on this headset. Thier aren’t many manufactured defects in the product meaning the battery should be your only fix needed. So today we will help you change your battery of an Astro A50 (2019). Hopefully, this guide helps you now & in the future.
Neye ihtiyacın var
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft -
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
