Ana içeriğe geç
Asus Eee PC T101MT Battery Replacement
Jarnell Miranda
Jarnell Miranda ve başka bir katkıda bulunan
En son October 5, 2019 tarihinde güncellendi
1 dakika
Çok kolay
If your tablet doesn't power on after charging, connect the power adapter. If it powers on after connecting the adapter, follow these steps to replace your battery.
Neye ihtiyacın var
Aletler
  1. Asus Eee PC T101MT Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, make sure your device is powered off and not connected to the power supply.
    • Turn the tablet over and position it so it matches the picture.
  2. Asus Eee PC T101MT Battery Replacement: adım 2, 1 resimden 1.
    • Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
  3. Asus Eee PC T101MT Battery Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
  4. Asus Eee PC T101MT Battery Replacement: adım 4, 1 resimden 1.
    • Lift the battery out of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jarnell Miranda
657 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Kuhn Fall 2015 Gateway, Team 1-1, Kuhn Fall 2015 üyesi
GCC-KUHN-F15S1G1
1 Üye
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,472
