Ana içeriğe geç
Asus F201E Install an SSD Replacement
Hans Wurst
Hans Wurst ve 5 diğer katkıda bulunanlar
En son May 13, 2021 tarihinde güncellendi
10 - 15 dakika
Kolay
Yanlış Araçlar
Daha İyi Resimler Gerekli
Hatalı İşaretlenmiş
Topluluk-Katkılı Kılavuz
Daha iyi giriş
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Asus F201E Install an SSD Replacement, Install an SSD: adım 1, 1 resimden 1.
    • First of all, remove the nine screws which hold the back plate.
    • ATTENTION: Be sure that you ground yourself, before proceeding. You can simply do that by touching a metal part of your heating for example. This ensures that you're completely electrically neutral. If you don't do this step, there is a risk of bricking your device.
  2. Asus F201E Install an SSD Replacement: adım 2, 1 resimden 1.
    • Remove the back plate carefully. I suggest to use a credit card or something similar as it is shown on the photo. This method avoids that you accidently crack the back plate. Take your time to do this, don't hurry.
    • As you go further, you will hear "clicks" occasionally. Don't worry, they just indicate that the back plate is loosening from the rest of your device.
  3. Asus F201E Install an SSD Replacement: adım 3, 1 resimden 1.
    • Once you're done, remove the back cover carefully.
    • Your device should look the one on the photo now.
  4. Asus F201E Install an SSD Replacement: adım 4, 1 resimden 1.
    • Here we go, this is our HDD. Loose the three screws which keep it fixed.
    • Afterwards you have to slide it to the left side (check the photo) in order to disconnect it.
    • You should then be able to put it out.
  5. Asus F201E Install an SSD Replacement: adım 5, 1 resimden 1.
    • It should look like this now.
  6. Asus F201E Install an SSD Replacement: adım 6, 1 resimden 1.
    • If your SSD is shipped without the metal tray, just use the tray from your old HDD.
    • Afterwards install the SSD the same way (only reversed of course) you just dismounted the HDD.
    • If you're done, it should look similar to the photo.
  7. Asus F201E Install an SSD Replacement: adım 7, 1 resimden 1.
    • Attach the back cover again and tighten the screws. I'd suggest to tighten them diagonally which means start with the one on the top left and on the bottom right, then the one on the top right and bottom left and so on.
    • If everything went fine, your BIOS/EFI should recognize your new SSD now. Congratulations, you fixed it! :)
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Hans Wurst
243 İtibar
1 Kılavuz yazıldı
4Kılavuz Yorumları
Hello, one question, is it not necessary to stick the black sticker with the foam stripes from the HDD to the SSD?
Tim - Yanıt
The procedure for Asus F200CA is similar, but there are screws hidden behind the two back feet.
For Tim and others: The foam stripes are probably only to cushion the HDD a bit. As an SSD is not sensitive to shocks the foam can be omitted.
Joonas Saarinen - Yanıt
Et pour le système d'exploitation Windows8, si le DD est récupéré sur un autre portable, y a t'il une manip particulière? faut-il racheter Windows?
Dan
danytech - Yanıt
Which ssd should I put into it?
Hugo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 21,201
