Ana içeriğe geç
Asus ROG G20CB RAM Replacement
Neye ihtiyacın var
    1. Asus ROG G20CB  RAM Replacement, Fan: adım 1, 2 resimden 1. Asus ROG G20CB  RAM Replacement, Fan: adım 1, 2 resimden 2.
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG G20CB  RAM Replacement: adım 2, 1 resimden 1.
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG G20CB  RAM Replacement: adım 3, 1 resimden 1.
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ROG G20CB  RAM Replacement: adım 4, 1 resimden 1.
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      FixBot'a Sor
      Yorum Ekle
    5. Asus ROG G20CB  RAM Replacement: adım 5, 1 resimden 1.
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      FixBot'a Sor
      Yorum Ekle
    6. Asus ROG G20CB  RAM Replacement: adım 6, 1 resimden 1.
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      FixBot'a Sor
      Yorum Ekle
    1. Asus ROG G20CB  RAM Replacement, CPU Cooler: adım 7, 1 resimden 1.
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG G20CB  RAM Replacement: adım 8, 1 resimden 1.
      • Push the optical drive out of the chassis.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG G20CB  RAM Replacement: adım 9, 1 resimden 1.
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ROG G20CB  RAM Replacement: adım 10, 1 resimden 1.
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
      FixBot'a Sor
      Yorum Ekle
    1. Asus ROG G20CB  RAM Replacement, RAM: adım 11, 1 resimden 1.
      • Gently push outward on the two retaining clips on either side of the RAM stick.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG G20CB  RAM Replacement: adım 12, 1 resimden 1.
      • The RAM module should pop up at an angle.
      • Pull the RAM stick out carefully by grasping it by the edges.
      • Avoid touching gold contacts.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Kimber-Starr
361 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Botvin Spring 2025 UMass Dartmouth, Team 3-3, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G3
3 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 18
Son 30 gün: 65
Her zaman: 690
