Ana içeriğe geç
Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement
Neye ihtiyacın var
  1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: adım 1, 3 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: adım 1, 3 resimden 2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Remove the inner steel plate that spins on the turntable.
    • Carefully lift up the plate.
    • Place it near your device out of the way.
  2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 2, 1 resimden 1.
    • Remove the power cord in the back of the device.
  3. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 3, 1 resimden 1.
    • Ensure that the Tone Arm clamp is in place.
  4. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 4, 2 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the eight 2 mm screws holding the back casing into place.
    • Carefully remove the back casing from the device to expose the interior.
  5. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: adım 5, 3 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: adım 5, 3 resimden 2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: adım 5, 3 resimden 3.
    • The Anti-Skate Knob is in the top left corner of the record player; this is what holds together the Tonearm.
    • To remove this, you must desolder the five small connections and the large one next to it.
  6. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 6, 2 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two screws.
    • Using Snap Ring Pliers, pull up at the Snap Ring to remove it.
  7. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 7, 2 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 7, 2 resimden 2.
    • Remove the 2.5 mm screws using a Phillips #2 that connects the tonearm to the record player frame.
  8. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 8, 3 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 8, 3 resimden 2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 8, 3 resimden 3.
    • Unscrew the cable with the Phillips #2 screwdriver.
  9. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 9, 3 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 9, 3 resimden 2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 9, 3 resimden 3.
    • Use a Philips #2 screwdriver to remove the two 2.5 mm screws, and remove the Snap Ring by pulling up at it with Snap Ring Pliers which are being highlighted.
    • DO NOT unscrew the yellow X in the picture.
    • Remove the small 0.1 mm black screw with the Phillips #000 screwdriver.
  10. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 10, 3 resimden 1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 10, 3 resimden 2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 10, 3 resimden 3.
    • Pull off the cover to reveal the spring.
    • Using Tweezers, pull the spring out by pulling it off of the hooks on each end.
  11. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: adım 11, 1 resimden 1.
    • Now replace the old spring with your new one!
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Ryan Barcelos
345 İtibar
1 Kılavuz yazıldı
Ekip
Cuesta, Team 20-3, Krynen Fall 2024 Cuesta, Team 20-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S20G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 170
