Ana içeriğe geç
Audio-Technica AT-LP120XUSB Velocity PCB Replacement
ATUS Service Dept
ATUS Service Dept ve başka bir katkıda bulunan
En son February 14, 2025 tarihinde güncellendi
10 - 30 dakika
Orta
Topluluk-Katkılı Kılavuz
This guide is used to provide step-by-step instructions for performing the replacement of
the Velocity PCB on the AT-LP120XUSB or AT-LP120XBT-USB. This procedure is used to resolve the following issues: 1) Inconsistent or no functionality when the Start/Stop button is pressed or On/Off dial is engaged. 2) Flickering red lights on power and speed switches.
No soldering is required to perform this repair.
The Velocity PCB part number is 704-120X-C057 and can be purchased directly through the Audio-Technica Parts Department: (330)686-3153 ext.5002 || parts@tli-atus.com
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: adım 1, 3 resimden 1. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: adım 1, 3 resimden 2. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: adım 1, 3 resimden 3.
    • Disconnect any cables from the rear of the turntable and move it to a clear surface.
    • With the turntable facing you, remove the following accessories and tie down the tonearm:
    • Dust Cover & Hinges
    • Black felt mat
    • Platter
    • Headshell & Counterweight
    • 45 Adapter
    • Any other loose accessories that may be on the surface of the turntable should be removed.
  2. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Removing Bottom Cover: adım 2, 1 resimden 1.
    • Before flipping the turntable upside-down, get a large soft object (ex. pillow, blanket, etc...) to minimize the possibility of damage.
    • Using a #PH1 Screwdriver, remove the 13 screws marked
    • Using a #PH0 Screwdriver, remove the 2 screws marked.
  3. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: adım 3, 3 resimden 1. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: adım 3, 3 resimden 2. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: adım 3, 3 resimden 3.
    • With the bottom panel removed, locate the Velocity PCB.
    • Locate the 3 connectors, and remove them from their corresponding PCBs.
    • Using a #PH0 screwdriver, remove these 6 screws.
    • After the screws are removed and connectors are loose, the Velocity PCB can be removed.
  4. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: adım 4, 3 resimden 1. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: adım 4, 3 resimden 2. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: adım 4, 3 resimden 3.
    • Before mounting the 6 screws, plug in the short connector to the Velocity PCB.
    • Mount the Velocity PCB using the guide post, and secure it with the 6 screws.
    • Connect the 2 longer leads to their corresponding PCBs.
  5. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Reassembly: adım 5, 1 resimden 1.
    • Place the bottom cover back on.
    • Using a #PH1 Screwdriver, secure the bottom cover with the 13 longer screws.
    • Using a #PH0 Screwdriver, secure the bottom cover with the 2 shorter screws.
Sonuç
Once the repair is completed, put all of your accessories back onto the turntable and reconnect any cables you were using.
For assistance balancing your tonearm, follow the guide attached below.
ATUS Service Dept
764 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 59
