Ana içeriğe geç
Beats Studio 2 Wireless Bluetooth Board Replacement
Neye ihtiyacın var
  1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: adım 1, 2 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: adım 1, 2 resimden 2.
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
    FixBot'a Sor
    Yorum Ekle
  2. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 2, 3 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 2, 3 resimden 2. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 2, 3 resimden 3.
    • Pull the rest of the cushion away from the adhesive with your hands.
    FixBot'a Sor
    Yorum Ekle
  3. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: adım 3, 2 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: adım 3, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
    FixBot'a Sor
    Yorum Ekle
  4. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 4, 1 resimden 1.
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
    FixBot'a Sor
    Yorum Ekle
  5. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 5, 2 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 5, 2 resimden 2.
    • Gently pull the wire with rubber connectors off of the speaker.
    FixBot'a Sor
    Yorum Ekle
  6. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 6, 1 resimden 1.
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
    FixBot'a Sor
    Yorum Ekle
  7. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: adım 7, 1 resimden 1.
    • Peel off the sticker underneath the speaker.
    FixBot'a Sor
    Yorum Ekle
  8. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 8, 1 resimden 1.
    • Remove the center screw using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 9, 1 resimden 1.
    • Separate the plastic case from the rubber backing by hand or with a spudger.
    FixBot'a Sor
    Yorum Ekle
  10. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 10, 2 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 10, 2 resimden 2.
    • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  11. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 11, 1 resimden 1.
    • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
    • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
    FixBot'a Sor
    Yorum Ekle
  12. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 12, 1 resimden 1.
    • Slide the front case down to separate it from the back and reveal the Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  13. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 13, 2 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 13, 2 resimden 2.
    • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
    • This will free the Bluetooth board from the back case.
    FixBot'a Sor
    Yorum Ekle
  14. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 14, 2 resimden 1. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 14, 2 resimden 2.
    • Remove the Bluetooth board from the case.
    • Remove the translucent sticker from the back of the Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  15. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 15, 1 resimden 1.
    • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
    FixBot'a Sor
    Yorum Ekle
  16. Beats Studio 2 Wireless Bluetooth Board Replacement: adım 16, 1 resimden 1.
    • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
    • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
    • The soldering iron can reach very high temperatures. Use it with caution.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jack Wilson
581 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 üyesi
UMASSD-RAMOS-S23S5G3
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 79
Her zaman: 2,906
