Ana içeriğe geç
Black and Decker CM0700BZ Water Tank Replacement
Neye ihtiyacın var
  1. Black and Decker CM0700BZ Water Tank Replacement, Lid: adım 1, 2 resimden 1. Black and Decker CM0700BZ Water Tank Replacement, Lid: adım 1, 2 resimden 2.
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Water Tank Replacement: adım 2, 3 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 2, 3 resimden 2. Black and Decker CM0700BZ Water Tank Replacement: adım 2, 3 resimden 3.
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Water Tank Replacement: adım 3, 3 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 3, 3 resimden 2. Black and Decker CM0700BZ Water Tank Replacement: adım 3, 3 resimden 3.
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Water Tank Replacement: adım 4, 2 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 4, 2 resimden 2.
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Water Tank Replacement: adım 5, 1 resimden 1.
    • To also remove the shower head, use the Shower Head guide.
  6. Black and Decker CM0700BZ Water Tank Replacement, Water Tank: adım 6, 2 resimden 1. Black and Decker CM0700BZ Water Tank Replacement, Water Tank: adım 6, 2 resimden 2.
    • Remove the carafe holder from the bottom of the coffee machine.
  7. Black and Decker CM0700BZ Water Tank Replacement: adım 7, 3 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 7, 3 resimden 2. Black and Decker CM0700BZ Water Tank Replacement: adım 7, 3 resimden 3.
    • Place coffee maker on its side, with the bottom facing you.
    • Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
  8. Black and Decker CM0700BZ Water Tank Replacement: adım 8, 3 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 8, 3 resimden 2. Black and Decker CM0700BZ Water Tank Replacement: adım 8, 3 resimden 3.
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
  9. Black and Decker CM0700BZ Water Tank Replacement: adım 9, 1 resimden 1.
  10. Black and Decker CM0700BZ Water Tank Replacement: adım 10, 3 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 10, 3 resimden 2. Black and Decker CM0700BZ Water Tank Replacement: adım 10, 3 resimden 3.
    • Remove the four 10 mm Phillips #1 screws.
    • Slowly pull the water tank up to expose the water pipes
  11. Black and Decker CM0700BZ Water Tank Replacement: adım 11, 2 resimden 1. Black and Decker CM0700BZ Water Tank Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Squeeze on the prongs with tweezers and hold.
    • Pull the water tank while squeezing the tighteners to loosen the water pipes off of the water tank.
Sonuç
Shawn Robichaud
729 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 UMass Dartmouth, Team 1-2, Shaddix Spring 2023 üyesi
UMASSD-SHADDIX-S23S1G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 245
