BlackBerry PlayBook USB Port Replacement
Giriş
1. adıma gitThe USB port is a common issue with these devices. Our example device's USB port was completely broken off the device. The port is attached to the motherboard by two solder joints, making it easy to reattach or replace once the motherboard has been removed.
Neye ihtiyacın var
Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the battery connector using either your fingers or a pair of tweezers.
With the spudger, remove the flat-top connector coming from underneath the motherboard.
Remove the clipped ZIF data connector coming from underneath the motherboard.
Lift up the black plastic clip with a spudger.
Pull the connector out gently using tweezers.
Remove the following five screws from the motherboard.
Three 1.5x2.5mm Phillips screws
Two 1.55x2.38mm Phillips screws
Lift all four antenna connectors from the motherboard again using the spudger.
Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
Use your soldering skills to detach the USB port from the motherboard at the following two solder joints.
14 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
excelent step by step guide not taking peoples knowledge for granted good stuff rgards pete smith.
Fantastically easy to follow step by step instructions with diagrams that are superbly explained - afterall I am but a 'mere woman's!! Thankyou, I love this site. Definitely *****
I was defeated but the USB port which has proof impossible to unsolder. I give up.. let’s just hold I have not damaged the board
i had tge same issue, cant desolder? what to do now, its in my hand right now.
