Giriş
A failing battery can impact daily use and pose safety risks. By replacing the battery, you can restore your phone's reliability, improve its lifespan, and avoid the need for a costly new device. Before replacing the battery, test with a different charger and inspect the charging port for debris. Make sure to not puncture the battery as it can be dangerous. Always power off the phone and disconnect it from any power source before starting. Use this guide to replace your device's battery.
Neye ihtiyacın var
Look for the two small holes at the top of your device.
Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
Pull the trays up and out of the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
