Ana içeriğe geç
Body Cover Removal
Body Cover Removal
Sam Gustafson
Sam Gustafson ve başka bir katkıda bulunan
En son February 18, 2025 tarihinde güncellendi
5 dakika
Kolay
Topluluk-Katkılı Kılavuz
How to remove the covers from the body of the camera.
Neye ihtiyacın var
  1. Body Cover Removal, Remove back cover: adım 1, 1 resimden 1.
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Body Cover Removal, Remove bottom cover: adım 2, 1 resimden 1.
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Body Cover Removal, Remove left front cover: adım 3, 1 resimden 1.
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Body Cover Removal, Remove front cover: adım 4, 2 resimden 1. Body Cover Removal, Remove front cover: adım 4, 2 resimden 2.
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Body Cover Removal, Remove right front cover: adım 5, 1 resimden 1.
    • Remove two 3.9 mm #00 screws.
Sonuç
Sam Gustafson
7.712 İtibar
42 adet Kılavuz yazıldı
2Kılavuz Yorumları
Do you know is the leatherette is removable?
cavjer123 - Yanıt
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
Sam Gustafson -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 395
