Ana içeriğe geç
Bose SoundLink Mini Speakers Replacement
Jordan Smith
Jordan Smith ve 6 diğer katkıda bulunanlar
En son January 14, 2024 tarihinde güncellendi
15 dakika
Orta
Yanlış Araçlar
This guide will assist you in replacing the speakers of the Bose SoundLink Mini. After time and normal use, the speakers may become unresponsive and require a replacement. Make sure you have all the necessary tools and follow all prerequisite guides in order to replace the two speaker parts.
NOTICE: A metal spudger is used in the guide, but a nylon spudger can be used too
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Bose SoundLink Mini Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
    Help I removed the part which I'm not supposed to next to the battery charger how do I put it back?
    Sooraj murali - Yanıt
    Where can I actually get a replacement battery????
    appreciate any help bc I couldn’t find it anywhere.
    Kamil M. - Yanıt
    Where can I get an actual replacement battery???
    Kamil M. - Yanıt
    Hi Brent and thank you for this easy fix.
    Still I have a problem I did not have while the original battery was in place: the sound is now buzzing even at a middle-of-the-range volume.
    I used the original screws and everything seems in place and the screws are tightened “right” I would say. I am usually fine fixing things. And I do not see what I could have done wrong…
    Any suggestion?
    Thank you.
    MBP - Yanıt
    Which battery is the correct one. Two model are shown to be purchase
    Ruben Roman - Yanıt
    What is not discussed is the wires that connect the battery to the speaker. In mine, I think I destroyed the speaker, because I pulled out the battery and dislodged the wires from the electronic board. I think they must have been soldered on, and now am having trouble attaching the new wires to the board.
    horseylawgal - Yanıt
    I have lost the 4 battery screws. What size are they? I think they are metric but what is the length? They were Philips head flat as I remember.
    Wolfgang Mitchell - Yanıt
  2. Bose SoundLink Mini Speakers Replacement: adım 2, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 2, 2 resimden 2.
    • While holding the cover back, pull straight up on the battery to remove it.
    Where can I buy this battery
    Karsten lou nielsen - Yanıt
    Well that part was simple. What I need is how to disconnect the ribbon cable which is soldered in on both ends. No help here.
    Art Kennedy - Yanıt
    soweit sogut..aber die Kabel sind verlötet ?
    das ist ja das problem
    also sehr schlechte Anleitung da ja das wichtigste fehlt !!
    Armin Karl - Yanıt
    Bonjour pas aussi simple car les câbles de la batterie d origine sont soudés…
    Lionel Ludosky - Yanıt
    On remark though: the original Bose battery has a thin foam gasket at the base. This foam gasket makes sure the room behind the speakers is airtight, which is essential for a clean sound. Most aftermarket batteries do not have this gasket, leading to a thumping noise when you turn up the music. This is easy to fix: with a sharp cutter, gently peel the gasket from the original battery and reinstall is on the new battery. That solved the problem for me. Alternatively, you can cut a think sheet of PE foam to fit the base of battery.
    philippe.bleiman - Yanıt
    Cable is not soldered on BOSE SoundLink Mini!
    The situation is different on BOSE SoundLink Mini II. The procedure to replace battery is more demanding as the cable is soldered.
    france.gartner - Yanıt
    iFixit日本語版からこのバッテリーパーツの購入ボタンを押すと、米国サイトにリンクされていて、当然ながらバッテリーは米国内以外では買えません!となります。何のための購入ボタンなんでしょうかね。時間の無駄でした。
    Shon DuBois - Yanıt
  3. Bose SoundLink Mini Speakers Replacement, Front/Back Protective Grille: adım 3, 1 resimden 1.
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
    Woher bekomme ich nun rin solches Vorder- und Rückgitter?
    [COBS]CR4ZY BLITZ - Yanıt
  4. Bose SoundLink Mini Speakers Replacement: adım 4, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 4, 2 resimden 2.
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  5. Bose SoundLink Mini Speakers Replacement: adım 5, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 5, 2 resimden 2.
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  6. Bose SoundLink Mini Speakers Replacement: adım 6, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 6, 2 resimden 2.
    • Repeat steps to remove the back grille.
    Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
    Pierre Payette - Yanıt
  7. Bose SoundLink Mini Speakers Replacement, Battery Cover: adım 7, 2 resimden 1. Bose SoundLink Mini Speakers Replacement, Battery Cover: adım 7, 2 resimden 2.
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
    le circuit de gauche ci-contre a les 4 vis de 15 mm prenez-en note.
  8. Bose SoundLink Mini Speakers Replacement: adım 8, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 8, 2 resimden 2.
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
  9. Bose SoundLink Mini Speakers Replacement: adım 9, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 9, 2 resimden 2.
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
    I just want to emphasize that the rubber tab (that is part of the cover) is supposed to sit ON TOP of the circuit board. In my case, my son managed to pull of the battery cover off completely, so as I was taking it apart I didn’t see how the rubber tab was actually supposed to sit inside the box. Because these instructions have you unseat the circuit board, I thought it was implying the tab was supposed to sit under the circuit board. But that is NOT the case! If I had looked at the pictures 7 and 9 more carefully, I would have seen how things were supposed to sit. Instead I first jammed things back together with the rubber underneath the board (really hard to do), only to find that the slightly squeezed rubber tab pushed the cover out a millimeter so it wouldn’t sit right on the charger. On closer inspection, I figured things out.
    Matthew Busche - Yanıt
  10. Bose SoundLink Mini Speakers Replacement, Button Switch Circuit Board: adım 10, 1 resimden 1.
    • Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
    • The black tab must be flipped up in order to reinsert the ribbon cable on reassembly.
    there’s supposed to be a wire strips lock behind that small,gray foam,careful fellas don’t end it like me,i just simply pulling it off until it teared apart the board, also it broked,and until know i haven’t fix it yet
    Kikay CianancyTM - Yanıt
    Button Switch Circuit Board is cut in my speaker what I do for it
    bodapati pramchand1997 - Yanıt
  11. Bose SoundLink Mini Speakers Replacement: adım 11, 3 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 11, 3 resimden 2. Bose SoundLink Mini Speakers Replacement: adım 11, 3 resimden 3.
    • Use a Metal Spudger to pry up the plastic divider.
  12. Bose SoundLink Mini Speakers Replacement: adım 12, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 12, 2 resimden 2.
    • When removing the plastic divider be careful not to damage the wire strip sliding through it.
  13. Bose SoundLink Mini Speakers Replacement: adım 13, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 13, 2 resimden 2.
    • Reach through the battery compartment hole and unplug the power strip shown.
    Hi ineed complete surkit bord for bose sound link mini speaker
    Ajay kumar - Yanıt
    Bose sound link mini 1 complete surkit prece?
    Ajay kumar - Yanıt
    How many pins a ribbon wire
    Rio Aldene Frani - Yanıt
  14. Bose SoundLink Mini Speakers Replacement: adım 14, 3 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 14, 3 resimden 2. Bose SoundLink Mini Speakers Replacement: adım 14, 3 resimden 3.
    • Remove both circuit boards by wiggling them up and out of the casing.
    • Unplug the speaker wires connected and fully remove both circuit boards.
    • When unplugging the speaker wires, squeeze the white connector piece to release the wires.
  15. Bose SoundLink Mini Speakers Replacement: adım 15, 2 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 15, 2 resimden 2.
    • Unhook the speaker wires clipped onto the button switch circuit board.
  16. Bose SoundLink Mini Speakers Replacement: adım 16, 3 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 16, 3 resimden 2. Bose SoundLink Mini Speakers Replacement: adım 16, 3 resimden 3.
    • Use a nylon or metal spudger to slightly lift up on the button switch circuit board.
    • Pull the button switch circuit board straight out from the casing.
    Hi
    my bose SoundLink mini keep flashing ember light even it’s plugged into AC adapter,can you tell me how can I get it update
    Moqdam Aljwrany - Yanıt
    hi dear
    hpe you are fine .dear need me one IC of this divice if posiable please inform me .thanks
    Aamir MAlik - Yanıt
  17. Bose SoundLink Mini Speakers Replacement, Speakers: adım 17, 2 resimden 1. Bose SoundLink Mini Speakers Replacement, Speakers: adım 17, 2 resimden 2.
    • Remove the eight 9.0 mm screws using the T8 Torx Screwdriver.
    Where can i find the spare speakers?
    Ricardo ferreira - Yanıt
  18. Bose SoundLink Mini Speakers Replacement: adım 18, 3 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 18, 3 resimden 2. Bose SoundLink Mini Speakers Replacement: adım 18, 3 resimden 3.
    • Using a nylon or metal spudger, pry up the plastic divider and remove it.
  19. Bose SoundLink Mini Speakers Replacement: adım 19, 3 resimden 1. Bose SoundLink Mini Speakers Replacement: adım 19, 3 resimden 2. Bose SoundLink Mini Speakers Replacement: adım 19, 3 resimden 3.
    • Gently lift the speakers up and out of the casing.
    Speaker dimensions pls L*w*h
    syalusg - Yanıt
    Welk type van speakers moet ik gebruiken? De huidige zijn niet meer te aanhoren door de rammelende basgeluiden. Waar kan ik nieuwe kopen of "witte producten" ? Bedankt al voor de info.
    ALFONS JANSSENS - Yanıt
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Jordan Smith
917 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G23
4 Üyeler
21 adet Kılavuz yazıldı
16Kılavuz Yorumları
This is great! Well done! Thank you. I dropped mine and there's not any sound now. What would you think happened and where should i start?
[deleted] - Yanıt
Perhaps open it up and then use a multimeter or some other speakers to see if you're getting any output from the amplifier? Sometimes the speaker drivers are damaged by dropping.
Larry Chen -
Do you know the part number for the speaker or where to buy it ? After a trip to the beach I now have a cracking sound in one of the speakers.
Thanks for the help
Javier Sanchez - Yanıt
Hi,
Where can i buy genuine Bose replacement speakers for the Soundlink?
Scott - Yanıt
Do you know if the the other speakers were passive radiators or powered subwoofers? Bose claims that the are subwoofers but I'm skeptical
Thomas Catanzarita - Yanıt
Hi, do you know if the oval speakers in the center of the speaker on the front and back are passive radiators or subwoofers? Bose claims that they are subwoofers but I'm skeptical and I doubt they are.
hello
its passive radiators
i do not know where to find those speakers ,i need those too
and for speaker model and other parts this will help :
https://www.google.mu/url?sa=t&rct=j&q=&...
neelmadhav dookhit - Yanıt
Hi, my Mini 2 has the main PCB faulty .  Do you know where can I find any spare parts?
Stefano Chiadini - Yanıt
Please how can I get my bose mini replacement speakers my is sounding like I’m trying to tone on radio
Bright chizzy - Yanıt
This article is not much help unless spare parts can be purchased. I can tear apart all day long and put back together but would really like to purchase “new" speakers!
Darby Skelley - Yanıt
speakers part number : bose 360563-0030 just hard to find…
tefiparis - Yanıt
Where can i buy the full case replacement?
carllesther.asy - Yanıt
Does anyone know what the dimensions of the speakers are in Bose Sound Link Mini? What is the best replacement?
Thanks,
Dino
Edin Handzic - Yanıt
Shed can I get replacement part BT-T11-V4.1 got Bose sound like mini.
jimmy hayhow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 49
Son 30 gün: 254
Her zaman: 46,643
