Ana içeriğe geç
Bose Soundlink II Battery Replacement
Kevin Bailey
Kevin Bailey ve 6 diğer katkıda bulunanlar
En son April 8, 2024 tarihinde güncellendi
2 - 4 dakika
Kolay
Daha iyi giriş
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: adım 1, 1 resimden 1.
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: adım 2, 1 resimden 1.
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: adım 4, 2 resimden 1. Bose Soundlink II Battery Replacement: adım 4, 2 resimden 2.
    • Carefully remove the battery by pulling it out of the speaker.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Kevin Bailey
476 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 22-4, Rauch Fall 2015 Texas Tech, Team 22-4, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S22G4
3 Üyeler
3 adet Kılavuz yazıldı
11 Yorum
Where i can buy one them battery model?
Daniel Campos - Yanıt
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - Yanıt
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - Yanıt
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - Yanıt
How much the battery only
Joboy De Guzman II - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 40
Son 30 gün: 154
Her zaman: 34,426
