Ana içeriğe geç
CAT S22 Flip Battery Replacement
Neye ihtiyacın var
  1. CAT S22 Flip Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
    • The screw will always be completely unscrewed after 4 full counter-clockwise rotations.
    • The screw cannot be completely removed so that you can’t lose the screw.
    FixBot'a Sor
    Yorum Ekle
  2. CAT S22 Flip Battery Replacement: adım 2, 1 resimden 1.
    • There is a slot on the upper left side of the back plate to insert the Spudger.
    • Use a spudger to pry up the back plate.
    FixBot'a Sor
    Yorum Ekle
  3. CAT S22 Flip Battery Replacement: adım 3, 1 resimden 1.
    • There is a slot to insert a spudger at the bottom of the battery.
    • Use a spudger to lift the battery out of the phone.
    • Do not operate on a devise with a swollen battery. Do not dispose of a swollen battery into general waste systems. You can dispose of the batteries with a qualified technician or facility.
    FixBot'a Sor
    Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Stephan Shaffer
234 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 20
Son 30 gün: 65
Her zaman: 287
