Ana içeriğe geç
CHUWI GemiBook XPro Battery Replacement
Neye ihtiyacın var
  1. CHUWI GemiBook XPro Battery Replacement, Lower Case: adım 1, 2 resimden 1. CHUWI GemiBook XPro Battery Replacement, Lower Case: adım 1, 2 resimden 2.
    • Discharge the battery below 25%, since a charged lithium-ion battery is a potential safety hazard. Fully power down the laptop and unplug any peripheries.
    • Orient the device to where you can see the bottom of the case.
    • Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
  2. CHUWI GemiBook XPro Battery Replacement: adım 2, 3 resimden 1. CHUWI GemiBook XPro Battery Replacement: adım 2, 3 resimden 2. CHUWI GemiBook XPro Battery Replacement: adım 2, 3 resimden 3.
    • Insert an opening pick into the gap between the lower case and the chassis.
    • Pry along the entire perimeter of the laptop until the lower case fully releases.
    • Lift the lower case up and off of the chassis.
  3. CHUWI GemiBook XPro Battery Replacement, Battery: adım 3, 2 resimden 1. CHUWI GemiBook XPro Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Peel off the black tape on the upper-right side of the motherboard.
  4. CHUWI GemiBook XPro Battery Replacement: adım 4, 2 resimden 1. CHUWI GemiBook XPro Battery Replacement: adım 4, 2 resimden 2.
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  5. CHUWI GemiBook XPro Battery Replacement: adım 5, 3 resimden 1. CHUWI GemiBook XPro Battery Replacement: adım 5, 3 resimden 2. CHUWI GemiBook XPro Battery Replacement: adım 5, 3 resimden 3.
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  6. CHUWI GemiBook XPro Battery Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  7. CHUWI GemiBook XPro Battery Replacement: adım 7, 3 resimden 1. CHUWI GemiBook XPro Battery Replacement: adım 7, 3 resimden 2. CHUWI GemiBook XPro Battery Replacement: adım 7, 3 resimden 3.
    • Lift the battery up and out of the chassis.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
JakeV
407 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 70
Her zaman: 230
