Canon EOS 30 LCD Screen Replacement
Giriş
1. adıma gitThis guide will show you how to access, remove, and replace the LCD screen. The process is safe and uncomplicated.
Neye ihtiyacın var
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the front panel by lifting it away from the camera's body.
To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
2 farklı kişi bu kılavuzu tamamladı.
