Ana içeriğe geç
Canon EOS Rebel T5 SD Card Board Replacement
Tyler Brown
Tyler Brown ve 5 diğer katkıda bulunanlar
En son January 10, 2025 tarihinde güncellendi
45 dakika - 1 saat
Orta
If your camera is no longer reading SD cards, you may find that you need to replace your card reader. This guide will show you the steps necessary.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Canon EOS Rebel T5 SD Card Board Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Board Replacement: adım 2, 1 resimden 1.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Board Replacement, SD Card: adım 3, 1 resimden 1.
  4. Canon EOS Rebel T5 SD Card Board Replacement: adım 4, 1 resimden 1.
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
  5. Canon EOS Rebel T5 SD Card Board Replacement, Back Cover: adım 5, 1 resimden 1.
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
    2 more screws behind rubber cover.
    Michael Gill - Yanıt
  6. Canon EOS Rebel T5 SD Card Board Replacement: adım 6, 1 resimden 1.
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  7. Canon EOS Rebel T5 SD Card Board Replacement: adım 7, 1 resimden 1.
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm JIS #000 screws.
    There is a 6th screw next to the battery door.
  8. Canon EOS Rebel T5 SD Card Board Replacement: adım 8, 1 resimden 1.
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
    Instructions are forgetting the two screws on either side of the viewfinder…. Viewfinder slides up to reveal two screws.
    Hugh Morand - Yanıt
  9. Canon EOS Rebel T5 SD Card Board Replacement: adım 9, 3 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement: adım 9, 3 resimden 2. Canon EOS Rebel T5 SD Card Board Replacement: adım 9, 3 resimden 3.
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
    Do NOT pry until you’ve removed the eye gasket, and the 2 screws behind this! You will break the camera.
  10. Canon EOS Rebel T5 SD Card Board Replacement, LCD Screen: adım 10, 2 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement, LCD Screen: adım 10, 2 resimden 2.
    • Remove the four silver 4mm JIS #000 screws connecting the LCD screen to the back of the camera.
    • Be sure to lift the ribbon cable to remove the remaining hidden black 4mm JIS #000 screw.
    The circled screw on the bottom in the middle isn’t a screw, it’s an alignment nub. The 4th screw is behind the black flex.
  11. Canon EOS Rebel T5 SD Card Board Replacement: adım 11, 1 resimden 1.
    • The LCD screen can now be lifted from the right side to be replaced.
    New LCD pressure fits into metal carrier tray. Assemble back together upside down, or LCD will fall out of tray.
  12. Canon EOS Rebel T5 SD Card Board Replacement, Motherboard: adım 12, 2 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement, Motherboard: adım 12, 2 resimden 2.
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
    • Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
    • When reconnecting the fiber optic cable, simply push the black cable into the hole in the connector and push it all the way in.
  13. Canon EOS Rebel T5 SD Card Board Replacement: adım 13, 1 resimden 1.
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm JIS #000 screws.
  14. Canon EOS Rebel T5 SD Card Board Replacement: adım 14, 3 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement: adım 14, 3 resimden 2. Canon EOS Rebel T5 SD Card Board Replacement: adım 14, 3 resimden 3.
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  15. Canon EOS Rebel T5 SD Card Board Replacement: adım 15, 1 resimden 1.
    • Remove the black 5 mm JIS #000 screw, located under the grip.
    they is a cable i think gray in color on the top panel, where does it fit, it seems to come out easily
    Tshepiso Marques Molefe - Yanıt
  16. Canon EOS Rebel T5 SD Card Board Replacement: adım 16, 1 resimden 1.
    • Remove the top panel of the device.
  17. Canon EOS Rebel T5 SD Card Board Replacement: adım 17, 2 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement: adım 17, 2 resimden 2.
    • Remove the front panel of the camera.
  18. Canon EOS Rebel T5 SD Card Board Replacement: adım 18, 3 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement: adım 18, 3 resimden 2. Canon EOS Rebel T5 SD Card Board Replacement: adım 18, 3 resimden 3.
    • Remove the five silver 5mm JIS #000 screws.
    • The motherboard can now be removed.
    Where can I buy a Motherboard for a T7 and what would the cost be?
    Dean Smith - Yanıt
  19. Canon EOS Rebel T5 SD Card Board Replacement, SD Card Board: adım 19, 3 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement, SD Card Board: adım 19, 3 resimden 2. Canon EOS Rebel T5 SD Card Board Replacement, SD Card Board: adım 19, 3 resimden 3.
    • Using a pair of tweezers, remove the tape covering the SD card board ribbon cable.
    • Using the plastic spuger, lift up the black locking tab on the SD card board ribbon cable and disconnect the ribbon cable.
  20. Canon EOS Rebel T5 SD Card Board Replacement: adım 20, 2 resimden 1. Canon EOS Rebel T5 SD Card Board Replacement: adım 20, 2 resimden 2.
    • Remove the three 3mm JIS #000 screws connecting the SD card reader to the back of the device.
    • Carefully lift the SD card board out of the camera.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tyler Brown
891 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G4
4 Üyeler
16 adet Kılavuz yazıldı
5Kılavuz Yorumları
Very comprehensive tutorial but 2 screws forgotten (on both sides of the viewfinder) and the adjustment thumb knob withdrawal before removing the top panel of the device. Good job anyway, tks
igloo - Yanıt
Is there a video of this?
Hubzilla - Yanıt
Removal of the sensor is NOT required to take the SD board out of the camera. The sensor needs to be fitted back to exactly the same height, otherwise you WILL not retain autofocus. Why was there no mention of this during the steps above?
Lee Gartside - Yanıt
Bonjour , ou peut on acheter le lecteur de carte sd , merci , cordialement
d007 Éric d007 - Yanıt
Step 19 and 20 are only for modifiing or replacing the image sensor
And is not recommended because AF doesn't work without further adjustment
Tom Oos Oss - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 10,417
