Ana içeriğe geç
Canon MF4700n Laser Toner Cartridge Replacement
Raymond Mach
Raymond Mach ve başka bir katkıda bulunan
En son March 20, 2023 tarihinde güncellendi
1 dakika
Çok kolay
If your Canon MF4700n (alternate model: MF4770n) printer prints out an uneven or partially faded print, prints white spots, smudges, or splatter, or if the printer is out of ink, use this guide to replace the toner cartridge in the printer.
A toner cartridge, also known as a laser toner, is commonly used in laser printers. The cartridge contains toner powder which is a mixture of color agents and plastic particles that last longer than ink cartridges.
A leaking toner cartridge can leak inside the printer. The leaked toner can be cleaned using a dry, lint free cloth after taking out the cartridge from the printer. Although printer toner is not toxic, it can be harmful to sensitive organs such as the eyes. If printer toner gets on the body, wash it off with soap and water. If the toner gets into the eyes, flush the eyes with clean water.
Before using this guide, make sure that the problem is the toner cartridge and not any other external issues.
Neye ihtiyacın var
  1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: adım 1, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: adım 1, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: adım 1, 3 resimden 3.
    • Turn off the printer.
    • Make sure that the energy saver button is not lit up. If it is, the printer needs to be turned off.
  2. Canon MF4700n Laser Toner Cartridge Replacement: adım 2, 2 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 2, 2 resimden 2.
    • Grab the operation panel and lift it up to reveal the toner cover.
    • Make sure there is nothing on top of the printer.
    • Potential for Device Damage: Forcing the operation panel to open may cause damage to the printer.
  3. Canon MF4700n Laser Toner Cartridge Replacement: adım 3, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 3, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 3, 3 resimden 3.
    • Open the toner cover to reveal the toner cartridge.
  4. Canon MF4700n Laser Toner Cartridge Replacement: adım 4, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 4, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 4, 3 resimden 3.
    • Grab the ledge of the cartridge and pull it out.
  5. Canon MF4700n Laser Toner Cartridge Replacement: adım 5, 2 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 5, 2 resimden 2.
    • Grab a new/working toner cartridge.
    • If the cartridge is new, then there will be plastic components on it. Follow the manual that comes with the new cartridge to remove the plastic components.
    • Shake the cartridge to distribute the toner evenly inside.
  6. Canon MF4700n Laser Toner Cartridge Replacement: adım 6, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 6, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 6, 3 resimden 3.
    • On both sides of the cartridge, there are two knobs sticking out.
    • Inside the toner cover, there are two toner guides, one on each side.
    • Align the knobs with the toner guides and push the cartridge securely all the way in.
  7. Canon MF4700n Laser Toner Cartridge Replacement: adım 7, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 7, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 7, 3 resimden 3.
    • Close the toner cover.
    • Lower the operation panel.
Sonuç
The Canon MF4700n Printer should print normally unless a different component is broken.
Bir başkası bu kılavuzu tamamladı.
Raymond Mach
212 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 91
Her zaman: 1,734
