Ana içeriğe geç
Canon MF4700n Laser Toner Cartridge Replacement
Neye ihtiyacın var
  1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: adım 1, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: adım 1, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: adım 1, 3 resimden 3.
    • Turn off the printer.
    • Make sure that the energy saver button is not lit up. If it is, the printer needs to be turned off.
  2. Canon MF4700n Laser Toner Cartridge Replacement: adım 2, 2 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 2, 2 resimden 2.
    • Grab the operation panel and lift it up to reveal the toner cover.
    • Make sure there is nothing on top of the printer.
    • Potential for Device Damage: Forcing the operation panel to open may cause damage to the printer.
  3. Canon MF4700n Laser Toner Cartridge Replacement: adım 3, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 3, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 3, 3 resimden 3.
    • Open the toner cover to reveal the toner cartridge.
  4. Canon MF4700n Laser Toner Cartridge Replacement: adım 4, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 4, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 4, 3 resimden 3.
    • Grab the ledge of the cartridge and pull it out.
  5. Canon MF4700n Laser Toner Cartridge Replacement: adım 5, 2 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 5, 2 resimden 2.
    • Grab a new/working toner cartridge.
    • If the cartridge is new, then there will be plastic components on it. Follow the manual that comes with the new cartridge to remove the plastic components.
    • Shake the cartridge to distribute the toner evenly inside.
  6. Canon MF4700n Laser Toner Cartridge Replacement: adım 6, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 6, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 6, 3 resimden 3.
    • On both sides of the cartridge, there are two knobs sticking out.
    • Inside the toner cover, there are two toner guides, one on each side.
    • Align the knobs with the toner guides and push the cartridge securely all the way in.
  7. Canon MF4700n Laser Toner Cartridge Replacement: adım 7, 3 resimden 1. Canon MF4700n Laser Toner Cartridge Replacement: adım 7, 3 resimden 2. Canon MF4700n Laser Toner Cartridge Replacement: adım 7, 3 resimden 3.
    • Close the toner cover.
    • Lower the operation panel.
Sonuç
The Canon MF4700n Printer should print normally unless a different component is broken.
Bir başkası bu kılavuzu tamamladı.
Raymond Mach
212 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 1,845
