Canon PowerShot A460 LCD Screen Replacement
Giriş
1. adıma gitInvolving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
Neye ihtiyacın var
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Since the tabs have been lifted, the ribbon should now slide out out easily.
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
