Ana içeriğe geç
Canon Powershot A720 IS Shutter Button Replacement
Neye ihtiyacın var
    1. Canon Powershot A720 IS Shutter Button Replacement, Shutter Button: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Carefully insert the tip of the tweezers in the space between the shutter button and the zoom dial. Gently insert the tip under the button and slowly lift.
      • If this step does not dislodge the shutter button, move on to step 2.
      • Do not force the tip of the tweezer or insert the tweezer too deep in between the shutter button and zoom dial. It will cause permanent cosmetic and button damage to the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon Powershot A720 IS Shutter Button Replacement: adım 2, 2 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 2, 2 resimden 2.
      • On the bottom of the camera, open the battery compartment by pushing the lock up. The door will then spring open allowing you to slide the batteries out.
      • If an SD card is also inserted, push on it to easily remove it from the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon Powershot A720 IS Shutter Button Replacement: adım 3, 3 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 3, 3 resimden 2. Canon Powershot A720 IS Shutter Button Replacement: adım 3, 3 resimden 3.
      • On the left side of the camera remove the two visible 4mm Phillips head screws.
      • On the right side of the camera remove the two visible 4mm Phillips head screws.
      • On the bottom of the camera remove the two visible 4mm Phillips head screws.
      FixBot'a Sor
      Yorum Ekle
    4. Canon Powershot A720 IS Shutter Button Replacement: adım 4, 3 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 4, 3 resimden 2. Canon Powershot A720 IS Shutter Button Replacement: adım 4, 3 resimden 3.
      • Slowly and gently pry open the back case panel from the rest of the camera.
      • The gray rubber cover labeled DC IN DIGITAL A/V OUT may fall out.
      FixBot'a Sor
      Yorum Ekle
    5. Canon Powershot A720 IS Shutter Button Replacement: adım 5, 1 resimden 1.
      • Remove the two 3 mm screws below the LCD screen using a Phillips #00 screwdriver.
      • Unscrew the top 4 mm Phillips head screw.
      FixBot'a Sor
      Yorum Ekle
    6. Canon Powershot A720 IS Shutter Button Replacement: adım 6, 2 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 6, 2 resimden 2.
      • Gently turnover the LCD screen so that the motherboard is exposed.
      • Carefully pull the ribbon cable straight out using your thumb and index finger.
      • The ribbon cable is fragile and will break if bent too much.
      FixBot'a Sor
      Yorum Ekle
    7. Canon Powershot A720 IS Shutter Button Replacement: adım 7, 2 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 7, 2 resimden 2.
      • Remove the 3mm Phillips head screw between the circuit boards.
      • Remove the three 3.5mm Phillips head screws on the circuit board.
      FixBot'a Sor
      Yorum Ekle
    8. Canon Powershot A720 IS Shutter Button Replacement: adım 8, 3 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 8, 3 resimden 2. Canon Powershot A720 IS Shutter Button Replacement: adım 8, 3 resimden 3.
      • Remove the gray rubber cover labeled DC IN DIGITAL A/V OUT if it hasn't fallen out yet on its own.
      • Carefully pull the front panel away from the rest of the camera.
      FixBot'a Sor
      Yorum Ekle
    9. Canon Powershot A720 IS Shutter Button Replacement: adım 9, 2 resimden 1. Canon Powershot A720 IS Shutter Button Replacement: adım 9, 2 resimden 2.
      • In the front panel remove the two 2.5mm Phillips head screws attached to the shutter button.
      • The shutter button and other components will fall out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ismael R
251 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Watkins Winter 2015 USF Tampa, Team 17-4, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 1,455
