Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Carefully insert the tip of the tweezers in the space between the shutter button and the zoom dial. Gently insert the tip under the button and slowly lift.
On the bottom of the camera, open the battery compartment by pushing the lock up. The door will then spring open allowing you to slide the batteries out.
On the left side of the camera remove the two visible 4mm Phillips head screws.
On the right side of the camera remove the two visible 4mm Phillips head screws.
On the bottom of the camera remove the two visible 4mm Phillips head screws.
Slowly and gently pry open the back case panel from the rest of the camera.
Remove the two 3 mm screws below the LCD screen using a Phillips #00 screwdriver.
Unscrew the top 4 mm Phillips head screw.
Gently turnover the LCD screen so that the motherboard is exposed.
Carefully pull the ribbon cable straight out using your thumb and index finger.
Remove the 3mm Phillips head screw between the circuit boards.
Remove the three 3.5mm Phillips head screws on the circuit board.
Remove the gray rubber cover labeled DC IN DIGITAL A/V OUT if it hasn't fallen out yet on its own.
Carefully pull the front panel away from the rest of the camera.
In the front panel remove the two 2.5mm Phillips head screws attached to the shutter button.
The shutter button and other components will fall out.
