Ana içeriğe geç
Casio CTK-501 Speaker Replacement
Neye ihtiyacın var
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: adım 1, 2 resimden 1. Casio CTK-501 Speaker Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
    FixBot'a Sor
  2. Casio CTK-501 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the bottom panel by lifting and pulling it towards yourself.
    FixBot'a Sor
  3. Casio CTK-501 Speaker Replacement: adım 3, 2 resimden 1. Casio CTK-501 Speaker Replacement: adım 3, 2 resimden 2.
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
    FixBot'a Sor
  4. Casio CTK-501 Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
    FixBot'a Sor
  5. Casio CTK-501 Speaker Replacement: adım 5, 1 resimden 1.
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
    FixBot'a Sor
  6. Casio CTK-501 Speaker Replacement: adım 6, 1 resimden 1.
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
    FixBot'a Sor
  7. Casio CTK-501 Speaker Replacement: adım 7, 1 resimden 1.
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
    FixBot'a Sor
  8. Casio CTK-501 Speaker Replacement: adım 8, 1 resimden 1.
    • Completely screw in the screws back into the original positions on the corner of the speaker.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jimmy Winne
578 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G16
4 Üyeler
1Rehber Yorum
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 82
Her zaman: 7,061
