Ana içeriğe geç
Chamberlain Garage Door Sensor Replacement
Orrett Bailey
Orrett Bailey ve başka bir katkıda bulunan
En son December 12, 2023 tarihinde güncellendi
25 dakika - 1 saat
Kolay
The garage door sensors prevent the garage door from closing on an object or a person in the garage doorway when it is attempting to close. When the sensors are faulty, the garage door remote may not work when pressed, causing the lights on the unit to blink.
This guide shows how to replace a Chamberlain garage door sensor. It is an easy procedure to perform and should take about thirty to forty-five minutes to complete. Minimal tools are required for this Fast Fix: a pair of wire strippers, a pair of pliers, and a step ladder.
The purchase of the replacement sensor based on the brand of garage door system is the part that is required to complete this project.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Chamberlain Garage Door Sensor Replacement, Sensor: adım 1, 1 resimden 1.
    • Use a step ladder to reach and unplug the garage door opener power cord.
  2. Chamberlain Garage Door Sensor Replacement: adım 2, 1 resimden 1.
    • Remove the wingnut from the safety sensor bracket.
    • Turn counter-clockwise until the wingnut is completely removed.
  3. Chamberlain Garage Door Sensor Replacement: adım 3, 2 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 3, 2 resimden 2.
    • Pull the sensor from the bracket.
    • Be careful not to lose the screw that attaches the sensor to the bracket.
  4. Chamberlain Garage Door Sensor Replacement: adım 4, 1 resimden 1.
    • Use the wire stripper or pliers to cut the wires for the sensor about an inch from the safety sensor.
    • This step removes the old sensor.
  5. Chamberlain Garage Door Sensor Replacement: adım 5, 3 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 5, 3 resimden 2. Chamberlain Garage Door Sensor Replacement: adım 5, 3 resimden 3.
    • Separate the ends of the wires
    • Use the wire stripper to strip the ends of the wires for the new sensor.
    • This step prepares the new sensor to be connected to the wiring for the garage door opener.
  6. Chamberlain Garage Door Sensor Replacement: adım 6, 3 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 6, 3 resimden 2. Chamberlain Garage Door Sensor Replacement: adım 6, 3 resimden 3.
    • Separate the ends of the wires and use the wire stripper to strip the ends of the wires going into the wall.
    • This step prepares the garage door opener wiring to be connected to the new sensor.
  7. Chamberlain Garage Door Sensor Replacement: adım 7, 3 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 7, 3 resimden 2. Chamberlain Garage Door Sensor Replacement: adım 7, 3 resimden 3.
    • Match the wires from the wall and from the new sensor and connect them with the crimp by inserting two like-kind wires in one crimp with one wire going into each side.
    • The black striped goes with the black striped wire.
  8. Chamberlain Garage Door Sensor Replacement: adım 8, 3 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 8, 3 resimden 2. Chamberlain Garage Door Sensor Replacement: adım 8, 3 resimden 3.
    • Use the pair of pliers to press down on the round section of the crimp to seal the connection.
    • Repeat for the other wire.
  9. Chamberlain Garage Door Sensor Replacement: adım 9, 1 resimden 1.
    • With the wiring connected, slide the new sensor into the bracket.
  10. Chamberlain Garage Door Sensor Replacement: adım 10, 1 resimden 1.
    • Attach the wingnut and tighten the new sensor to the bracket.
  11. Chamberlain Garage Door Sensor Replacement: adım 11, 1 resimden 1.
    • Repeat the process for the other sensor on the other side of the garage door.
  12. Chamberlain Garage Door Sensor Replacement: adım 12, 1 resimden 1.
    • Use a step ladder to reach and plug in the power cord for the garage door sensor.
  13. Chamberlain Garage Door Sensor Replacement: adım 13, 2 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 13, 2 resimden 2.
    • Gently wiggle the sensors to align them.
    • When the sensors are aligned, the sensor with the green safety light glows steadily.
  14. Chamberlain Garage Door Sensor Replacement: adım 14, 3 resimden 1. Chamberlain Garage Door Sensor Replacement: adım 14, 3 resimden 2. Chamberlain Garage Door Sensor Replacement: adım 14, 3 resimden 3.
    • Place a box between the sensors and press the garage door button to close the garage door. The garage door should return to its starting point and the garage door light flash. This result means that the new sensors are working properly.
Bitiş Çizgisi
Orrett Bailey
229 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 81
Her zaman: 822
