Ana içeriğe geç
Cleaning the Sensors of the Cassida Counterfeit Detector
TREVOR j NELMS
TREVOR j NELMS ve 3 diğer katkıda bulunanlar
En son July 31, 2024 tarihinde güncellendi
Tahmin yok
Orta
Daha İyi Resimler Gerekli
Daha iyi giriş
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Cleaning the Sensors of the Cassida Counterfeit Detector, Cassida Counterfeit Detector: adım 1, 1 resimden 1.
    • Remove the rubber legs.
  2. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 2, 1 resimden 1.
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 3, 1 resimden 1.
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 4, 1 resimden 1.
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 5, 1 resimden 1.
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 6, 1 resimden 1.
    • All the parts disassembled.
  7. Cleaning the Sensors of the Cassida Counterfeit Detector, Cleaning the Sensors of the Cassida Counterfeit Detector: adım 7, 1 resimden 1.
    • Remove the 4 screws that are circled with a Phillips #1 screwdriver.
    • Then lift up on the green motherboard.
  8. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 8, 1 resimden 1.
    • Once the motherboard is removed from the grey case, flip it over to expose the sensors.
  9. Cleaning the Sensors of the Cassida Counterfeit Detector: adım 9, 1 resimden 1.
    • Clean the three sensors circled with isopropyl alcohol and a cue tip.
Sonuç
Bir başkası bu kılavuzu tamamladı.
TREVOR j NELMS
543 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 1,394
