Ana içeriğe geç
Contixo V9 Motherboard Replacement
Neye ihtiyacın var
  1. Contixo V9 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Contixo V9 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Find the separation line between the front and back side of the device on the outer edge of the tablet.
    • Use the plastic opening tool to pry apart the tablet, lifting the face off.
  2. Contixo V9 Motherboard Replacement: adım 2, 3 resimden 1. Contixo V9 Motherboard Replacement: adım 2, 3 resimden 2. Contixo V9 Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the three screws along the perimeter of the motherboard using the Phillips #000 screwdriver to unscrew.
  3. Contixo V9 Motherboard Replacement: adım 3, 3 resimden 1. Contixo V9 Motherboard Replacement: adım 3, 3 resimden 2. Contixo V9 Motherboard Replacement: adım 3, 3 resimden 3.
    • Locate the three golden ribbons along the perimeter of the motherboard.
    • There are two dark tabs; pull each away from the cream connection port. Once tabs are in open position remove the gold ribbon.
    • Flip up the dark tab and pull the gold ribbon away.
    • Do not pull the the cables harshly as it could rip the ribbon.
    • Reference this guide for more help with attaching or detaching cables.
  4. Contixo V9 Motherboard Replacement: adım 4, 3 resimden 1. Contixo V9 Motherboard Replacement: adım 4, 3 resimden 2. Contixo V9 Motherboard Replacement: adım 4, 3 resimden 3.
    • Locate the battery on the opened tablet.
    • Use the spudger or one of the blue iFixit tools to lift the battery from the base of the tablet.
    • It is possible to use your hand to pry the battery away from the base of the tablet but not recommended.
  5. Contixo V9 Motherboard Replacement: adım 5, 3 resimden 1. Contixo V9 Motherboard Replacement: adım 5, 3 resimden 2. Contixo V9 Motherboard Replacement: adım 5, 3 resimden 3.
    • Detach the motherboard from the battery by pressing the soldering tip tool to each of the three connection points.
    • Exercise caution when desoldering the battery.
    • The tool located in the pictures is not the soldering tip tool but rather used for reference of where to detach.
    • Reference this guide for more help with soldering and desoldering the connections.
  6. Contixo V9 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the motherboard from the base of the device. Switch with replacement.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 99
