Ana içeriğe geç
Crosley CR8005A Needle Replacement
Austin Davenport
Austin Davenport ve 2 diğer katkıda bulunanlar
En son July 29, 2020 tarihinde güncellendi
1 - 6 dakika
Orta
If the needle in your Crosley CR8005A is damaging your records, or not playing with the same quality it used to have, this guide will help you replace the needle.
First, make sure that the records are cleaned thoroughly to ensure that the skipping and damage is not being caused by dust and debris.
  1. Crosley CR8005A Needle Replacement, Needle: adım 1, 1 resimden 1.
    • Pick up the needle arm and locate the needle.
  2. Crosley CR8005A Needle Replacement: adım 2, 1 resimden 1.
    • Carefully pull down on the front edge of the needle.
  3. Crosley CR8005A Needle Replacement: adım 3, 1 resimden 1.
    • Slide the needle towards you then pull outwards and remove the needle.
Sonuç
To reassemble your device, follow these steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
Austin Davenport
189 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 27
Son 30 gün: 76
Her zaman: 5,355
