Ana içeriğe geç
DJI Mini 2 Drone Body Replacement
Neye ihtiyacın var
  1. DJI Mini 2 Drone Body Replacement, Battery: adım 1, 2 resimden 1. DJI Mini 2 Drone Body Replacement, Battery: adım 1, 2 resimden 2.
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Drone Body Replacement: adım 2, 2 resimden 1. DJI Mini 2 Drone Body Replacement: adım 2, 2 resimden 2.
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
    Honestly, did we need an ifixit tutorial on THIS?!
    Next up, how to insert the battery.
    Big Ed - Yanıt
    @big_ed Perhaps author wanted to make sure no electric issues to occur @people who are not aware of possible damages whilst having battery still inside.. Next up, a smart remark?
    Ruud - Yanıt
    Merci 🔥 pour le tuto j'avais oublié comment on fait
    Layoness Record - Yanıt
    Merci à vous pour ce bref mais incontournable tutoriel permettant l'accès à la batterie !
    Albert Brian Frank - Yanıt
  3. DJI Mini 2 Drone Body Replacement, Drone Body: adım 3, 2 resimden 1. DJI Mini 2 Drone Body Replacement, Drone Body: adım 3, 2 resimden 2.
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Drone Body Replacement: adım 4, 2 resimden 1. DJI Mini 2 Drone Body Replacement: adım 4, 2 resimden 2.
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Drone Body Replacement: adım 5, 3 resimden 1. DJI Mini 2 Drone Body Replacement: adım 5, 3 resimden 2. DJI Mini 2 Drone Body Replacement: adım 5, 3 resimden 3.
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Drone Body Replacement: adım 6, 2 resimden 1. DJI Mini 2 Drone Body Replacement: adım 6, 2 resimden 2.
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Drone Body Replacement: adım 7, 2 resimden 1. DJI Mini 2 Drone Body Replacement: adım 7, 2 resimden 2.
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jacob Matos
1.167 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team F-1, Gurgel Spring 2022 UMass Dartmouth, Team F-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SFG1
2 Üyeler
15 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where to buy a new drone body ?
Loïc Sarda - Yanıt
Same Q. Where to buy drone body? Please email me. Thanks
Ruud - Yanıt
Look for it on Google directly or in Amazon there are websites dedicated to sell the hole body parts
Pedro Burgos -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 67
Son 30 gün: 305
Her zaman: 7,525
