DJI Mini 2 Drone Body Replacement
Giriş
1. adıma gitWe are defining the DJI Mini 2 drone body as the top and bottom plastic panels of the drone. These panels are the blockaded between the insides of the drone and the outside world.
The drone body stores the inner electronic parts of the drone like the GPS, the Main Board, and the wires the drone uses. Damage to the drone body can cause the drone to be unstable in flight. If the body of the drone is damaged they will need to be replaced.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Face the DJI Mini 2 away from you so that you are looking at the charging ports.
Use your finger to open up the back panel.
Pinch the locking mechanism on the battery to release the lock.
Pull the battery straight out of the compartment.
Merci 🔥 pour le tuto j'avais oublié comment on fait
Merci à vous pour ce bref mais incontournable tutoriel permettant l'accès à la batterie !
Unfold the wings of the drone.
Place the drone upside down on a flat surface.
8 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Where to buy a new drone body ?
Look for it on Google directly or in Amazon there are websites dedicated to sell the hole body parts
